how can i connect AP-125 and config
  • 1.  how can i connect AP-125 and config
    Posted Apr 11, 2014 01:13 PM
    i'm using AP-125 for frist time
    so need help to connect Ap-125 to pc by console cable and what software i need to config it
    thats the frist time i use the console config so plz help me
  • 2.  RE: how can i connect AP-125 and config
    Posted Apr 11, 2014 01:14 PM
    You need a controller for the AP125 to work....
  • 3.  RE: how can i connect AP-125 and config
    Posted Apr 11, 2014 01:22 PM
    what a controller ? is it software
  • 4.  RE: how can i connect AP-125 and config
    Posted Apr 11, 2014 02:00 PM
  • 5.  RE: how can i connect AP-125 and config
    Posted Apr 11, 2014 02:07 PM
    The AP-125 cannot operate on its own; it needs a mobility controller as cjoseph suggests.   The mobility controller is an appliance that centrally manages campus based access points (including the AP-125).
    http://www.arubanetworks.com/products/mobility-controllers/
