How can I create a certificate through command line?
  • 1.  How can I create a certificate through command line?
    Posted Jun 14, 2018 04:12 PM
    Hello Team!
    I wanna ask you something. Is there a way to generate certificates though command line? I need to access or generate it exaclty from the apache server. Is it possible?
    here is the command that I want to use
    openssl req -new -newkey rsa:2048 -out guest.aruba.porvenir.com.co.csr -keyout guest.aruba.porvenir.com.co.key
  • 2.  RE: How can I create a certificate through command line?
    Posted Jun 14, 2018 04:26 PM
    Certificate for what?
  • 3.  RE: How can I create a certificate through command line?
    Posted Jun 14, 2018 05:50 PM
    A need to generate a request sign so a trusted entity can sign it. But I need to generate it from CLI (I believe on the linux machine in which the Clearpass is setup).
    I know that I can generate it from the web access. But, every time I do that, the entity is saying that there is some kind of mistake so they had me do it direclty by command line.
    I just want to know if it is possible.
  • 4.  RE: How can I create a certificate through command line?
    Posted Jun 14, 2018 05:53 PM
    CSRs for ClearPass can be generated via the GUI or externally on another machine using OpenSSL.
