How can I delete a OS image?
This thread has been viewed 22 times
  • 1.  How can I delete a OS image?
    Posted Jul 12, 2012 07:16 AM
              I am trying to upgrade to release ArubaOS_6xx_6.1.3.3_34156 and believe i have insufficient free flash in either partion -
     #show storage
    Filesystem                Size      Used Available Use% Mounted on
    none                    300.0M      1.6M    298.4M   1% /tmp
    /dev/mtdblock11         156.0M      4.2M    151.8M   3% /flash
    /dev/mtdblock9           50.0M     46.7M      3.3M  93% /mnt/img0
    /dev/mtdblock10          50.0M     46.7M      3.3M  93% /mnt/img1
    #show image ver
    Partition               : 0:0 (/dev/mtdblock9) **Default boot**
    Software Version        : ArubaOS 6.0.1.0 (Digitally Signed - Production Build)
    Build number            : 27504
    Label                   : 27504
    Built on                : Sat Mar 19 01:22:34 PDT 2011
    Partition               : 0:1 (/dev/mtdblock10)
    Label                   : 27504
    Built on
    Is it possible to delete the old OS image in Partion1 and then ftp the new image to this partition?
    Thanks in advance
    Mike
  • 2.  RE: How can I delete a OS image?
    Posted Jul 12, 2012 07:39 AM
    No, but according to the release notes, you can free up space by:
    Remove all unnecessary saved files from flash by navigating to Maintenance > Delete Files
