How can I determine if TurboQAM (256-QAM) is enabled on an IAP-225?
  • 1.  How can I determine if TurboQAM (256-QAM) is enabled on an IAP-225?
    Posted Aug 12, 2014 11:18 AM
    Additionally, how can I enable it if it's not enabled?
    Will enabling this feature disrupt any connectivity with any legacy devices?
    -Ryan
  • 2.  RE: How can I determine if TurboQAM (256-QAM) is enabled on an IAP-225?
    Posted Aug 12, 2014 09:20 PM
    TurboQAM support was introduced in the controller-based AP-22x in AOS 6.4.2.0.
    For Instant, support will likely appear in v.4.1.1.x this quarter.
    Keep in mind that TurboQAM is a Broadcom-to-Broadcom feature and only works with TurboQAM enabled NICs.  Be sure to check your NIC specs to see if it is supported.
