How can I disable CNA bypass
  • 1.  How can I disable CNA bypass
    Posted May 07, 2016 12:36 PM
    I want to use captive portal for login. However, all the iphone could not pop up the splash page once the wifi connected. Does the IAP can disable the apple CNA bypass option?
  • 2.  RE: How can I disable CNA bypass
    Posted May 07, 2016 12:40 PM
    Are you using ClearPass?
  • 3.  RE: How can I disable CNA bypass
    Posted May 07, 2016 12:58 PM
    No, just using virtual control and choose the splash page type as  facebook.
  • 4.  RE: How can I disable CNA bypass
    Posted May 25, 2016 07:13 AM
    the instant section would be a better place for this.
    from what i can find the CNA bypass with instant is done with the walled garden functionality, do you have that setup perhaps?
    does it work with the build in captive portal?
