How can I do math actions in a value in an enforcement policy?
  • 1.  How can I do math actions in a value in an enforcement policy?
    Posted Jul 23, 2018 05:10 AM
    Is there documentation how can I do math actions in a value in an enforcement profile?
    I need to set Radius session time out which is a result of a formula:
    %{Endpoint:MAC-Auth Expiry}-%{Authorization:[Time Source]:Now}
    This formula does not work. Perhaps becasue I need to convert to number, or maybe the minus sign sgould not be like that.
    The bigger picture is that I need to allow a device to remain connected until it is profiled, bit disconnect it after a given time (10 mins), becuase this is a scheduled SNMP scan time.
    So I give an expiry time of 10 mins and check the time now vs the expiry time.
    The problem is that if the is re-auth before the session timout, it reset the session timout period. So I have to apply a new session time out for the remining time.
  • 2.  RE: How can I do math actions in a value in an enforcement policy?
    Posted Jul 23, 2018 09:37 AM
    You’d need to do it in a SQL auth source.
  • 3.  RE: How can I do math actions in a value in an enforcement policy?
    Posted Jul 23, 2018 10:38 AM
    problem is I need to calc from 2 different auth sources: time source for the time now, and an expiry time from the endpoint reporistory.
    I think it is not possible, isn't it?
