How can I get alerted on Access Point with red light?
  • 1.  How can I get alerted on Access Point with red light?
    Posted May 07, 2024 02:11 PM
    Occasionally our 515 or 505 WAPs will go into a problem state displaying a red LED light. In this state, clients cannot connect to them, but the on-prem Controller (7205 running 8.12.0.0) does not report them as "down". This has been the case on both the current OS and previous 8.10 and 8.7 OS.
    Does anyone know if there is a way to get alerted (via email) by the controller or SNMP if a WAP goes red-light like this?
    We do have SNMP monitoring in place, but it (like the controller) is currently only looking at up/down status.
    Demetri
  • 2.  RE: How can I get alerted on Access Point with red light?
    Posted May 07, 2024 09:43 PM
    Have you any information as to why the AP is going into an error state?  Opened a TAC case to resolve whatever error is occurring or replace the hardware if necessary?
    Carson Hulcher, ACEX#110
  • 3.  RE: How can I get alerted on Access Point with red light?
    Posted May 08, 2024 09:49 AM
    Red Light is due to maxed cpu usage
  • 4.  RE: How can I get alerted on Access Point with red light?
    Posted May 08, 2024 09:55 AM
    Red LED for the system status indicates a general system error condition - not necessarily because of or exclusive to CPU usage. Data from the AP would be needed to confirm.
  • 5.  RE: How can I get alerted on Access Point with red light?
    Posted May 08, 2024 10:10 AM
    Well that is what is reported in Central when we experience this issue on our 615s.  We have over 350 APs deployed.
    We haven't experienced many instances since moving to 10.5/10.6 and collapsing our building based clusters to large singular campus groups
    But it is an chain effect situation. All it takes is one AP to cause a gradual cascading effect through an entire cluster. A reboot of each AP will clear it until the next one
    Logo  Description automatically generated
    Icon  Description automatically generated with medium confidence  Icon  Description automatically generated   An orange slice with a white background  Description automatically generated with low confidence
    Mr. Scott McCambley
    Manager of Network, Server & Cloud Infrastructure
    P.O. Box 3013 - 2 Ridley Road
    St. Catharines, Ontario L2R 7C3
    905-684-1889 x2218
    ridleycollege.com
    signature_2362232615
    If you require technical support, simply click the button below to submit a ticket.
    signature_1103703789
  • 6.  RE: How can I get alerted on Access Point with red light?
    Posted May 08, 2024 10:17 AM
    Your AOS 10 experience doesn't exactly apply to an AOS 8 controller based setup.
