how can i get the IPsec preshared key of the master controller
This thread has been viewed 52 times
  • 1.  how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 03:28 AM
    Hi all,
    i`m new to aruba world ,we have a master controller (192.168.1.148)that`s running fine and i need to set up a local controller(192.168.1.149) and configure redundancy .the problem is that i don`t know the ipsec preshared key that is configured on the master controller . i tried to use `encrypt disable` but i didn`t know where to look on the running config :
    i have the below config on the master :
    Crypto Map "default-psk-redundant-master-ipsecmap" 9999 ipsec-isakmp
    Crypto Map Template"default-psk-redundant-master-ipsecmap" 9999
                     IKE Version: 1
                     IKEv1 Policy: All
                     Security association lifetime seconds : [300 -86400]
                     Security association lifetime kilobytes: N/A
                     PFS (Y/N): N
                     Transform sets={ default-ml-transform }
                     Peer gateway: 192.168.1.149
                     Interface: VLAN 0
                     Source network: 192.168.1.148/255.255.255.255
                     Destination network: 192.168.1.149/255.255.255.255
                     Pre-Connect (Y/N): Y
                     Tunnel Trusted (Y/N): Y
                     Forced NAT-T (Y/N): N
                     Uplink Failover (Y/N): N
                     Force-Tunnel-Mode (Y/N): N
                     IP Compression (Y/N): N
    how can i get the preshared key from the master ? if i need to use `encrypt enable `which part of the config i need to look to ?thank you in advance
  • 2.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 03:43 AM
    You are correct on the 'encrypt disable' to see the key, however you will need to look for the 'localip' command to find the key. Just a note, the Master-Local relationship can also be configured using MAC's of each device as well.
    https://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/localip.htm
  • 3.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 03:59 AM
    hi,
    Thank you for your answer however when i do `encrypt disable` then `show localip` i got nothing :
    (WW-CTRLR-BCKUP) #encrypt disable
    (WW-CTRLR-BCKUP) #show localip
    Local Switches configured by Local Switch IP
    Switch IP address of the Local Key
  • 4.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 04:05 AM
    If you have no locals configured already, just create a new shared key and
    use that :)
  • 5.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 04:31 AM
    hi zalion0,
    thank you for your answer but there is already a site to site vpn configured between controllers so there must be a preshared key configured isn`t ? my question is how to get that key instead of creating new one ? if that possible
  • 6.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 04:43 AM
    hi Zalion0 ,
    just to add one more thing ,one i check the site to site vpn configuration between the two controllers ,i can see the below :
    (WW-CTRLR-BCKUP) #show crypto-local ipsec-map
    IKE Version: 1
    IKEv1 Policy: All
    PFS (Y/N): N
    Interface: VLAN 0
    however when i try to display the preshared key for that vpn ,i got nothing :
    (WW-CTRLR-BCKUP) #show crypto-local isakmp key
    ISAKMP Local Pre-Shared keys configured for ANY FQDN
    Key Representation
    ISAKMP Local Pre-Shared keys configured by FQDN
    FQDN of the host Key Representation
    ISAKMP Local Pre-Shared keys configured by Address
    IP address of the host Subnet Mask Length Key Representation
    ISAKMP Global Pre-Shared keys configured by Address
    so i really not sure what to do now ,will configuring new preshared key using the localip command will overwrite the prehared key configured between the two controller and solve the connectivity issue ? thank you in advance for your answer
  • 7.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 04:46 AM
    These might not be using a PSK for the Master-Local IPSEC, you can use a MAC (based on cert as well). So it would be worth checking this too. This command is run from the master.
    (Aruba620) #show running-config | include local-factory-cert
    Building Configuration...
    local-factory-cert local-mac "xx:xx:xx:xx:xx:xx"
    To confirm you have Locals attached, you can also run the following:
    #show switches
     Just a note, looking at your Crypto Map, this is showing as Master Redundancy (e.g Master/Master Backup) as opposed to Master-Local
    Spoiler
    Crypto Map Template"default-local-master-ipsecmap-xx:xx:xx:xx:xx:xx" 9999
    Again, this is only based on snippets of config.
  • 8.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 04:53 AM
    Hi Zalion0,
    thank you for your answer but  they are using IPSec Key for authentication because that`s checked on the web GUI of the master controller .
     but i excuted the commands you provide and there was no certificate using :
    (WW-CTRLR-BCKUP) (config) #show running-config | include local-factory-cert
    (WW-CTRLR-BCKUP) (config) #show switches
    All Switches
    IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    192.168.1.148 WW-CTRLR-BCKUP Building1.floor1 master OAW-4450 6.5.4.9_67129 up UPDATE SUCCESSFUL 0 2
    Total Switches:1
    what do you suggest ? do i confifure new local preshared key using the local ip command or there is something else we can do ?thank you in advance
  • 9.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 04:59 AM
    Based on the show switches, you provided there is no locals connected.
    This will provide you further information.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/Explanation-about-quot-show-switches-summary-quot-command-and-it/ta-p/215239
    On the other controller, if you run show switches do you see the same output?
    If you cannot remember the key, then you will need to change it and also change it on any local controllers.
    You can run the below command on each of the controllers to identify if it is a Master, Master Standby or a Local
    #show roleinfo
  • 10.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 05:11 AM
    there is no connectivity right now between the two controllers because i keep entring the wrong key :
    Jan 14 12:42:31 fpcli: USER:admin@192.168.18.173 COMMAND:<master-redundancy peer-ip-address 192.168.1.148 ipsec "west1234" > -- command execution failed
    Jan 14 12:43:30 fpcli: USER:admin@192.168.18.173 COMMAND:<master-redundancy peer-ip-address 192.168.1.148 ipsec "west1234" > -- command execution failed
    thats why i asked the question on first place so i can achieve connectivity between the controller ,now even the ping fails because of the wrong preshared key so of course it won`t be any local controllers on the show switch output .
    thank you
  • 11.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 05:31 AM
    The command in the last post shows you trying to set up/change the Master Redundancy PSK, not the Local PSK used for local controllers. These are two different things.
    You can have a PSK for Master Redundancy and you can have another PSK for Master Local operations.
    The command is failing because of another reason (no VRRP for example or device isn't a Master) not because the PSK is wrong.
    Have you followed the guides to set up Master-Master Backup and also Master-Local? You might find it easier to simply overwrite the existing keys with new keys based on what you are trying to achieve.
    Do you want to provide the previously suggested commands on from each controller?
    #show roleinfo
    #show vrrp
  • 12.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 05:45 AM
    Hi Zalion,
    My mistake i didn`t explain the situation well ,or maybe i`m confused between master/local redundancy and vrrp redundancy
    here is the situation anyway : we have a running master controller (which also have a vrrp configuration on it )
    I have a second controller whcih is on factory default state so i need to configure it then set up redanduncy .
    i still on the basic setup ,still didn`t configure vrrp on local controller when i set the second controller as local ,i enter the master ip(as master ip address) address but for authentication ,i need to entern the IPsec key so it can connect to the master .
    i don`t have that key and that`s what i need to know .
    or let me ask the question differently :when i do the basic config ,when i need to enter the master ip address and then the ipsec key ,which key i need to use ,is it the vrrp authentication key ,is it the site to site vpn preshared key ?
    Thank you
  • 13.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 06:24 AM
    If you have no Local controllers already configured, there will be no Master-Local PSK set so this is why you cannot find one :)
    To set up a Master-Local for example:
    On the Master :
    (host) (config) #localip 0.0.0.0 ipsec gw1234567
    On the Local:
    (host) (config) #masterip 10.1.1.250 ipsec gw1234567
    Might be worth reading the VRD for WLAN Redundancy as this explains it far better then me. In short, these are different.
    A IPSEC tunnel is used for Master-Local communications.
    A IPSEC tunnel is used for Master-Master Backup communications (which also uses VRRP).
    A IPSEC tunnel can also be used to establish a traditional tunnel between controllers.
    Master-Master Backup needs to be in the same L2 broadcast domain due to using VRRP.
    Master-Local can be L2/L3 separated as no VRRP is required.
  • 14.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 09:13 AM
    hi Zalion ,
    Thank you for your help .
    so as you recomended,this is what i did :
    on the master controller :
    localip 0.0.0.0 ipsec *******
    on the local :
    masterip 192.168.1.148 ipsec*******
    >>everything works fine and connectivity between controller is working and on show switches i can see both the master and the local
    (WW-CTRLR-BCKUP) #show switches
    All Switches
    IP Address Name Location Type Model Version D
    192.168.1.148 WW-CTRLR-BCKUP Building1.floor1 master OAW-4450 6.5.4.9_67122
    192.168.1.149 OAW-4450-local Building1.floor1 local OAW-4450 6.5.4.9_67122
    however when i start configuring  vrrp ,issues  start happening :(
    so can you please help me understanding the below:
    - after setting up master-local ,can i set up vrrp because i think vrrp can only be used with master-master setup?if i can`t use vrrp ,then does the setup i made ,the master-local setup will be enough to acheive redundancy or in other word does redundancy achieved by vrrp or by master-local setup ?thank you so much
  • 15.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 09:19 AM
    You can set up VRRP between a Master-Local providing they are in the same L2. What type of redundancy are you looking to use? AP, controller, interface etc? Each of these have different options based on your network design.
  • 16.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 09:33 AM
    HI Zalion,
    first of all ,thank you for all the help and i`m sorry for all the questions
    i need to steup redundancy between the two controllers(the master and the local ) so when the master fails ,the standby controller can take over and the APs connecting to the master can switchover to the standbye .
    i have this config on the master :
    master-redundancy
    master-vrrp 150
    peer-ip-address 192.168.1.149
    vrrp 150
    priority 110
    authentication west1234
    ip address 192.168.1.150
    description "Preferred-Standby"
    vlan 1
    tracking master-up-time 30 add 20
    no shutdown
    then when i try configuring redundancy on the local controller ,when i type :
    `master-redundancy` i got an error`Error: Master IP 192.168.1.148 is configured`  so i just ignore that command and enter the below :
    vrrp 150
    priority 110
    vlan 1
    no shutdown
    then the ping times out between the controller and i can`t change the master ip on the local controller to the virtual ip >
    in the guide you sent me its mentioned that we can use vrrp either with master-master setup or local-local steup
  • 17.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 09:37 AM
    If you have configured this as Master-Local you cannot configure Master-Master redundancy as well, these are different controller roles. You're best bet is to configure a VRRP for AP Discovery and use HA Groups for AP redundancy. These are detailed in the VRD's.
    Do you have an Aruba partner you can work with?
  • 18.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 09:53 AM
    hi Zalion,
    Thank you for your answer and honestly don`t know about aruba partner because i`m new at the company and need to check that .
    i have a last question if you don`t mind .
    right now i have master-local setup working fine and i have all the AP connected to the master controller
    if i go to the LMS  AP and do the following :
    LMS ip= ip add of the master
    Backup LMS IP=ip add of the local
    does that mean if the master fails ,the APs will reboot and switchover to the local controller ?thank you so much
  • 19.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 09:57 AM
    It will do, however if you look at the HA Fast Failover options the AP will
    built a standby tunnel to the secondary controller and not require a reboot
    during failover.
  • 20.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 09:59 AM
    ok ,thank you so much for all the help :) much appreciated
  • 21.  RE: how can i get the IPsec preshared key of the master controller
    MVP EXPERT
    Posted Jan 15, 2019 10:00 AM
    You're welcome :)
  • 22.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 15, 2019 04:28 AM
    I have the same doubt. Can anyone reply..
  • 23.  RE: how can i get the IPsec preshared key of the master controller
    Posted Jan 18, 2019 11:55 AM
    from CLI
    encrypt disable
    show runn
    masterip is listed.
  • 24.  RE: how can i get the IPsec preshared key of the master controller
    Posted Aug 02, 2021 01:22 PM
    encrypt disable
    Madhura Naik
