The default mgmt user admin of AOS controllers cannot be removed, only non-default root users can be deleted.
(WLC01) [mynode] (config) #show mgmt-user
Default password recovery user: Enabled
Management User Table
USER PASSWD ROLE STATUS PATH Max-concurrent-sessions
admin ***** root ACTIVE / N/A
manager ***** root ACTIVE / N/A
(WLC01) [mynode] (config) #no mgmt-user admin
Cannot Delete Default user admin.
(WLC01) [mynode] (config) #no mgmt-user manager
(WLC01) ^[mynode] (config) #write m
There is an option to disable authentication using local accounts (including admin) when external RADIUS and TACACs servers are reachable. Have a look at page 890.
Disabling Authentication of Local Management User Accountshttps://support.hpe.com/hpesc/public/docDisplay?docId=a00072769en_us(WLC01) [mynode] (config) #show mgmt-user local-authentication-mode
Local Authentication Mode: Enabled
(WLC01) [mynode] (config) #no mgmt-user localauth
Saving Configuration...
Configuration Saved.
Local Authentication Mode: Disabled
Emil Gogushev
Original Message:
Sent: Apr 02, 2022 11:17 PM
Subject: How can i remove admin account from my Aruba JL479A 8320 switch
Thanks, Parnassus
For this help,
One more thing i have an Aruba WLCAruba7205 with an 8.5.0.6 firmware version it also has a default admin user can it be deleted or disabled?
If there is any document please share it with me.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/06410fe769434248b14a332b7245e550.png)
sanjib behera
Original Message:
Sent: Apr 02, 2022 05:03 AM
Hi Sanjib,
Aruba AOS-CX 10.09 Security Guide for 8320, 8325, 8400, 10000 Switch Series (Edition 1, December 2021)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/3af1215c100e42cbba508ea0c3507e7f.png)
Davide Poletto
Original Message:
Sent: Apr 01, 2022 10:08 AM
Hi team,
Can anyone help me out with how i can remove admin account from myAruba JL479A 8320 switch, instead of using admin account i can only use the authorized user accounts.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/dfb399536d9045659b04b48e06ff9865.png)
If this admin user can not be deleted ,is there any proper documentation for this please share with me for the reference.
sanjib behera
