How can I save the password in Captive Portal Web Authentication?
  • 1.  How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:14 PM
    Everyday I have to Authentication on the webside.
  • 2.  RE: How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:17 PM
    There is no way to save the password (unless your browser has an auto fill
    add-in). The alternate solution would be to use ClearPass' MAC caching
    feature which will bypass the captive portal for a defined time before
    requiring reauthentication.
  • 3.  RE: How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:20 PM
    But the longest time only 4.5 hours
  • 4.  RE: How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:23 PM
    Do you have ClearPass? You can get around the 4.5 hour limitation with the
    MAC caching feature.
  • 5.  RE: How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:28 PM
    Yes,I have  ClearPass,How to do ?
    My  ClearPass version is ClearPass Policy Manager 6.0.1.46054
  • 6.  RE: How can I save the password in Captive Portal Web Authentication?
    Posted Nov 29, 2013 09:39 PM
    The "Guest MAC authentication" service template in CPPM (Configuration >
    Service Templates) will guide you and create the appropriate service
    entries.
    You'll need to update to at least 6.1.
