how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
  • 1.  how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
    Posted Jul 15, 2014 04:40 PM
    could you tell me (step by step) how can I configure authentication ( on the Aruba controller) ? my hardware it's Aruba 650  and 4 AP 105 (  campus mode) my Aruba650 is connected with Radius server and communications it's ok (I check "diagnostic tab on controller" and event viewer on Radius server )....but I don't know how can I configure policy and roles? ...i try two weeks and nothing ... our workers can't connected to "internal wireless network"
    thank you for help ...(my boss wanna kill me ;) )
  • 2.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
  • 3.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
    Posted Jul 15, 2014 09:39 PM
    PFA for WS 2003 IIS step by step config.
    Add radius server in controller.
    Configuration -> Authentication -> Servers -> Radius Server
    Nik..
    Attachment(s)
    pdf
    IAS2003+Config.pdf   1.70 MB 1 version
  • 4.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
    Posted Jul 16, 2014 01:55 AM
    Hi, thank you for solutions... I have domain controller and radius (working ok - user have a grant access) is added to the controller but question is - which policy and roles must be add in the aruba (vlan for role must be assigned?) i have to use default role and policies?
  • 5.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
  • 6.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
    Posted Jul 16, 2014 02:03 AM
    Did you already try to use the Campus LAN Wizard to setup your network (Configuration> Wizards> Campus LAN)?  It should have asked you the VLAN and role you want your users to be in.
  • 7.  RE: how can i set up authentications RADIUS (ws2003) step by step? - i'm a novice ;)
    Posted Jul 16, 2014 10:16 PM
    You are using radius authentication. If you have selected WPA2+AES security then role will be authenticated.
    If you want to assign multiple internal vlan to user group with single SSID  then you will have to use user derivation rule.
    There is AP group name is "default" in controller. Policy will be assigned as per role.
    Kindly provide screenshot for clearity.
    Nik...
