How can I tell if a 3200 has been upgraded to 1GB of memory or if I already have an 3200XM?
  • 1.  How can I tell if a 3200 has been upgraded to 1GB of memory or if I already have an 3200XM?
    Posted Sep 03, 2013 11:48 PM
    Can someone point out to me if the following is from either a 3200, 3200 with upgraded memory or a 3200XM ?  I don't have physical access to the controller, neither can I reboot it to check the boot messages...
    (aruba3200) #show mem
    Memory (Kb): total: 760772, used: 310540, free: 450232
    (aruba3200) #show ver
    ArubaOS (MODEL: Aruba3200), Version 6.1.3.1
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2012, Aruba Networks, Inc.
    Compiled on 2012-03-13 at 00:28:42 PDT (build 32786) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.0.1 (build 34416)
    Built: 2012-07-09 23:41:24
    Built by: p4build@re_client_34416
    Switch uptime is 308 days 6 hours 1 minutes 3 seconds
    Reboot Cause: Power Failure.
    Supervisor Card
    Processor XLR 508 (revision C4) with 1254M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
    (nplaruba3200) # show inventory
    Supervisor Card slot            : 0
    System Serial#                  : BGxxxxxxx
    SC      Assembly#               : 2xxxxxxx (Rev:08.00)
    SC      Serial#                 : Fxxxxxxxx (Date:07/27/12)
    SC      Model#                  : Aruba3200
    HW MAC Addr                     : 00:0B:86:xx:xx:xx to 00:0B:86:xx:xx:xx
    CPLD Version                    : (Rev: 1.3)
    #3200
  • 2.  RE: How can I tell if a 3200 has been upgraded to 1GB of memory or if I already have an 3200XM?
    Posted Sep 04, 2013 07:16 AM
    show switchinfo
  • 3.  RE: How can I tell if a 3200 has been upgraded to 1GB of memory or if I already have an 3200XM?
    That particular output has been upgraded.   The total value showing:  760772 indicates the new memory DIMM: the older output would have been 354124.
  • 4.  RE: How can I tell if a 3200 has been upgraded to 1GB of memory or if I already have an 3200XM?
    Posted Sep 04, 2013 04:56 PM
    Thank you for the simple answer I was after :)
    Now I can upgrade to 6.2.1.3 in confidence (requirement of upgrade was 1GB memory).
    Can you understand my confusion when the CPU shows > 1GB memory and the memory command shows < 1GB memory?  Is there a reason behind this?
