How can I turn AP to IAP
This thread has been viewed 21 times
  • 1.  How can I turn AP to IAP
    Posted Feb 21, 2014 08:52 AM
    Hi All,
    How can I upgrade AP to IAP, can I upgrade it using apboot menu ?
    apboot> ?
    ? - alias for 'help'
    boot - boot the OS image
    clear - clear the OS image or other information
    dhcp - invoke DHCP client to obtain IP/boot params
    factory_reset - reset to factory defaults
    help - print online help
    mfginfo - show manufacturing info
    osinfo - show the OS image version(s)
    ping - send ICMP ECHO_REQUEST to network host
    printenv - print environment variables
    purgeenv - restore default environment variables
    reset - Perform RESET of the CPU
    saveenv - save environment variables to persistent storage
    setenv - set environment variables
    tftpboot - boot image via network using TFTP protocol
    upgrade - upgrade the APBoot or OS image
    version - display version
    apboot>
  • 2.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:07 AM
    a RAP is not convertible to iAP but the other way it's possible.
  • 3.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:10 AM
    Unit is originaly IAP-92, I want to turn back to IAP-92 again. There is nothing to do with RAP.
  • 4.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:42 AM
    There should be a small hole on the bottom.  Stick a paper clip in there, power up, and wait until the power LED flashes quickly.  That will convert it back
  • 5.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:55 AM
    "There should be a small hole on the bottom.  Stick a paper clip in there, power up, and wait until the power LED flashes quickly.  That will convert it back"
    I tried that, did not work.
  • 6.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:57 AM
    call support!
  • 7.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 02:08 PM
    Try it again; make sure you hold the paperclip in there while powering up for at least 5 seconds before releasing th reset button.  See the diagram and instructions below.   If it doesn't work, call support as Seth suggests.
  • 8.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 03:18 PM
    You can console in to the AP and reset the AP using the reset button at the same time, you can see the boot sequence and if it had cleared the config.
  • 9.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 04:57 PM
    If factory reset is not working, please share the following info from APBOOT:
    Output of ?printenv'
    Output of ?mfginfo?
    Output of ?osinfo?
    Also, another way of doing factory reset is the command ?factory_reset? in APBOOT.
    However, I recommend against performing upgrade in APBOOT without clear instructions from Aruba.
    Yan
  • 10.  RE: How can I turn AP to IAP
    Posted Feb 24, 2014 02:36 AM
    Output of ?mfginfo?
    Output of ?osinfo?
    Yan
    apboot> PRİ   p
    ping purgeenv printenv
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Scapa
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=6c:f3:7f:c2:06:9a
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    Environment size: 206/65532 bytes
    apboot> mfginfo
    Manufacturing info:
    System S/N : BU0032561
    Date Code : 082512
    Base MAC : 6c:f3:7f:c2:06:9a
    MAC Count : 1
    CPU Assembly : 0YY90KP0
    CPU Major Rev : 11
    CPU Brd Variant : 00
    CPU Board S/N : YA2870A79
    Country Code : UNRST
    PROM Format : 1
    Checksum : 90
    apboot> osinfo
    Partition 0 does not contain a valid OS image
    Partition 1 does not contain a valid OS image
  • 11.  RE: How can I turn AP to IAP
    Posted Jul 10, 2018 06:44 AM
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Scapa
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=24:de:c6:c1:c2:52
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    apboot> mfginfo
    Manufacturing info:
    System S/N : BU0152828
    Date Code : 100913
    Base MAC : 24:de:c6:c1:c2:52
    MAC Count : 1
    CPU Assembly : 0AR50KP0
    CPU Major Rev : 10
    CPU Brd Variant : 01
    CPU Board S/N : R539O0974
    PROM Format : 1
    Checksum : c9
    apboot> osinfo
    apboot> purgeenv
    Un-Protected 1 sectors
    .done
    Erased 1 sectors
    Writing
    apboot> saveenv
    Saving Environment to Flash...
    .done
    Erased 1 sectors
    Writing
    apboot> boot
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    Invalid image format version: 0x0
    eth0 down
    DHCP broadcast 1
    eth0 down
    DHCP broadcast 2
    eth0 down
    DHCP broadcast 3
    eth0 down
    DHCP broadcast 4
    eth0 down
    DHCP broadcast 5
    eth0 down
  • 12.  RE: How can I turn AP to IAP
    Posted Jul 10, 2018 07:28 AM
    It does not look like ethernet0 is plugged into anything.
  • 13.  RE: How can I turn AP to IAP
    Posted Feb 21, 2014 09:47 AM
    use the purgeenv command the sequence would be as follows :
    purgeenv
    saveenv
    boot
  • 14.  RE: How can I turn AP to IAP
    Posted Feb 24, 2014 02:41 AM
    purgeenv
    saveenv
    boot
    Hit <Enter> to stop autoboot: 0
    apboot>
    apboot> purgeenv
    .done
    Erased 1 sectors
    Writing
    apboot> saveenv
    .done
    Erased 1 sectors
    Writing
    apboot> boot
    @Checking image @ 0xbf100000
    @Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP broadcast 2
    DHCP broadcast 3
    DHCP broadcast 4
    DHCP broadcast 5
  • 15.  RE: How can I turn AP to IAP
    Posted Mar 03, 2014 02:23 PM
    did that resolve it for you?
  • 16.  RE: How can I turn AP to IAP
    Posted Mar 03, 2014 03:58 PM
    I upraded with new IAP image.
  • 17.  RE: How can I turn AP to IAP
    Posted May 09, 2014 09:44 AM
    Thats wonderful that you solved it by upgrading the image! Exactly how did you do this? I am having the exact same problem, could you perhabs do a step by step solution and/or link me in the right direction? Many thanks!
  • 18.  RE: How can I turn AP to IAP
    Posted May 15, 2014 08:56 AM
    factory_reset command should have worked for you instead of purgeenv from the console.
  • 19.  RE: How can I turn AP to IAP
    Posted May 16, 2014 06:33 AM
    make sure to flash the correct partition , as the IAP has partiiton_1 containing "always" the IAP OS , and partition0 containing a copy from it , and can be temporarily flashed with controller-based flash for the IAP to be running as AP .
    i had once the same problem and i had to setenv the correct partition and then i was able to recover or reflash .
