How can I view single-band only clients?
  • 1.  How can I view single-band only clients?
    Posted Dec 07, 2017 01:27 PM
    In the CLI on a ArubaOS (MODEL: Aruba7220-US), Version 6.5.3.3 controller and I use the command: #show ap association. In the bottom of the output I notice that it shows me:
    Total num of single-band only clients:8
    How do I find out which 8 clients those are?
    Also, are there any tools that help with this in Airwave?
    Thanks!!
    Rob
  • 2.  RE: How can I view single-band only clients?
    Posted Dec 07, 2017 01:30 PM
    show ap association | exclude B
  • 3.  RE: How can I view single-band only clients?
    Posted Dec 07, 2017 05:04 PM
    This gets me close but l'm not sure how to interpret the result. For example I receive:
    Num Clients:913
    Total num of dual-band capable clients:846
    Total num of dual-band capable clients in 2.4G band:62
    Total num of dual-band capable clients in 5G band:784
    Total num of single-band only clients:6
    #show ap association | exclude B gives me the following output:
    23 clients are listed that are authenticated (auth: y) but not associated (assoc: n). Then there is a single client that is authenticated and associated and shows all the SSID information, phy, assoc. time, etc.
    The "Num Clients" = 913. But then I do "total of dual-band capable" + "single band only" = 852.
    A few questions about this:
    -Why the discrepancy in the amount of clients compared to dualband/singleband?
    -Why does it mean that I have 23 clients that are authenticated but not associated?
    -Also, the command you provided shows one client that is not capable of Band Steering, but the summary says there should be 6 single band only clients.
  • 4.  RE: How can I view single-band only clients?
    Posted Dec 07, 2017 05:34 PM
    You should go to Dashboard> Clients to see the total and the breakdown.
  • 5.  RE: How can I view single-band only clients?
    Posted Dec 07, 2017 11:37 PM
    Num Clients:913
    it's meant to match up, here is an example
    Num Clients:127
    Total num of 5G capable clients:126
    Total num of 5G capable clients in 2.4G band:22
    Total num of 5G capable clients in 5G band:104
    Total num of 2.4G only clients:1
    a clue should be able to be found in the combined output of these:
    no paging
    show ap association
    show user-table
    show ap ess
    show ap arm client-match summary
    if you DM it to me I can have a look, else, raise a tac case if you're on a recent software version
