I think a command output showing the temp, should be completing this thread.
(host) #show ap power-mgmt-statistics ap-name 00:4e:35:c4:47:06
AP Power Mgmt Status, Last update at 2019-09-26 16:43:13
Attr Value
LLDP Granted Power Eth 0: 23.3 Eth 1: 23.3
LLDP Request Power Eth 0: 23.3 Eth 1: 23.3
Temperature Highest temperature: 52°C, Lowest temperature: 48°C, Current temperature: 50°C
Power Supply POE-AT
USB Status USB Knob: Auto, USB Status: Disabled
PSE Status N.A.
ETH Status Eth 0:Enabled. Eth 1:Disabled.
G-radio Chain 4*4
G-radio Enable Enabled
G-radio Power Full Power
A-radio Chain 4*4
A-radio Enable Enabled
A-radio Power Full Power
CPU Throttle 100%
Power Consumption 7.6W
IPM Enable Disabled
Original Message:
Sent: Dec 25, 2019 11:19 AM
Subject: How can i view the current operating temperature of my AP-135 and AP-225s on my network?
To be clear, the command above is only supported on the 534, 535 and 555 series 802.11ax access points.
