When i use Insight to get posture data, it goes only as deep as showing a module os healthy or not. I could not make a report which shows the status of each compnent in the posture.
The desired report (per the customer) is a list of all clients and the posture of each single component: apps, reg keys, files, folders etc.
Is there a way to do it with Insight, or do I need to use SQL query for that?
