How can over 400 users to connect IAP-225 IN IAP Mode ?
  • 1.  How can over 400 users to connect IAP-225 IN IAP Mode ?
    Posted Dec 23, 2015 05:50 AM
    Dear all,
    User Guide:
    Max clients threshold
    Specify the maximum number of clients that can be configured for each BSSID on a WLAN in the text box. You can specify a value within the range of 0 to 255. The default value is 64.
    If I set the value to
    Mean what ??
    Setting:
    Thanks~
    #AP225
  • 2.  RE: How can over 400 users to connect IAP-225 IN IAP Mode ?
    Posted Dec 23, 2015 06:53 AM
    That is a maximum number.  In the real world, nobody has 255 or 400 clients on a single access point.
  • 3.  RE: How can over 400 users to connect IAP-225 IN IAP Mode ?
    Posted Dec 23, 2015 08:43 PM
    Thanks, cjoseph.
    I have 5 IAP-215 and more then 10 IAP-225.  haha~
  • 4.  RE: How can over 400 users to connect IAP-225 IN IAP Mode ?
    Posted Dec 24, 2015 09:38 PM
    Nobody cann't connect when I set the value to 0. .....
