How can upgrade os in CLI
  • 1.  How can upgrade os in CLI
    Posted Nov 13, 2013 05:07 AM
    I want upgrade 5.0.3.2 to 6.2.1.4,but i cannot upgrade in webui,so i want upgrade in cli .how can i do
  • 2.  RE: How can upgrade os in CLI
    Posted Nov 13, 2013 07:09 AM
    copy tftp: <tftpserveripaddress> <filename> system partition 1 <filename>
    you will need to copy it onto the partition which is not the current boot partition - either 1 or 0. The device will automatically boot from the partition you just copied it onto with the new OS.
    Show boot command will tell you which is the current boot partition.
