how can we connect 2 sites using Wired AP ?
  • 1.  how can we connect 2 sites using Wired AP ?
    Posted Nov 17, 2014 05:44 AM
    hey there
    i have site A and site B , A is ocnnected directly to the Backhaul , B has no backhaul and its conencted to site A via outdoor AP , i used wirted Ap profile to configure on eht0 site A`s Vlan .
    Site B came up on a testing controller and got configurations from siite A , once i did it on life controller it didnt work .
    Please advice .
    Digram is attached ..
  • 2.  RE: how can we connect 2 sites using Wired AP ?
    Posted Nov 17, 2014 07:52 AM
    You need to configure it as a mesh portal/point
  • 3.  RE: how can we connect 2 sites using Wired AP ?
    Posted Nov 18, 2014 06:21 AM
    Hi victor
    Its already configured , mesh portal on site A and point on site B .
  • 4.  RE: how can we connect 2 sites using Wired AP ?
    Posted Nov 18, 2014 08:50 AM
    Is your switch on the other end configured with a trunk or access port?
  • 5.  RE: how can we connect 2 sites using Wired AP ?
    Posted Nov 18, 2014 09:01 AM
    Is the Site B AP (mesh point) connecting to Site A (mesh portal) when at the remote site?    You say it came up on testing controller, but not live controller....so I wasn't sure if you are even getting it to come up.
    Did you provision the mesh point against the live controller with its mesh cluster profile while it was at Site A?   If your test controller is not part of the same master/local topology, this may be an issue.
