How can we make the controller to authenticate from LDAP?
  • 1.  How can we make the controller to authenticate from LDAP?
    Posted Jun 10, 2014 04:28 PM
    I need to know how to make controller authentcate from LDAP
  • 2.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 10, 2014 04:29 PM
    Wireless users or management access?
  • 3.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 10, 2014 04:45 PM
    Thank you for instant replaies I need to know it for both
  • 4.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 10, 2014 05:13 PM
    Adams,
    Have you searched the documentation, or the knowledgebase here for the answer?
  • 5.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 11, 2014 11:16 AM
    yes I have did and it didn't worka the user guide said so I asked here for a help with step by step I May missing some thing
  • 6.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 11, 2014 03:33 PM
    Here is the thread on how to incorperate AD accounts to access the controllers for management purpose.
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Using-LDAP-AD-account-to-login-into-the-7210-Controllers/m-p/160048#M33997
  • 7.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 14, 2014 12:02 PM
    Dear this is for mangmet I need to now what about normal user authentication and machine authentcation?
  • 8.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 14, 2014 04:21 PM
    You cannot do machine authentication through LDAP.  If you want to do that, you should setup a radius server (NPS) and use that to authenticate both your users and machines:  http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/Step-by-Step-How-to-Configure-Microsoft-NPS-2008-Radius-Server/ta-p/80672
  • 9.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 15, 2014 07:10 AM
    Even for user authentication I should setup RADIUS between LDAP and controller?
  • 10.  RE: How can we make the controller to authenticate from LDAP?
    Posted Jun 15, 2014 12:17 PM
    ADAMS,
    If you use LDAP, you have to install and manage supplicant software on all the laptops that needs to authenticate, and then you will NOT be able to do machine authentication.  LDAP is challenging to implement for 802.1x.   If the users need machine authentication, you will have to  switch away from LDAP and then use radius anyway.  You should use radius from the beginnning.
