How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
  • 1.  How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
    Posted Jun 12, 2015 03:14 PM
    For wireless point to point bridge setup, how can we tell if the antennas (directional or sectoral) are fully aligned?
    Is there an integrated LED indicator (for alignment) that displays signal strength on the AP?
  • 2.  RE: How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
    Posted Jun 12, 2015 03:20 PM
    Which access point?
  • 3.  RE: How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
    Posted Jun 12, 2015 03:26 PM
    Aruba 270 series APs.
  • 4.  RE: How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
    Posted Jun 12, 2015 03:44 PM
    It does not have a light.  You will need to run a command to see the RSSI
    (Aruba7650-US) #show ap mesh neighbors ap-name Mesh-225
    Neighbor list
    MAC                Portal             Channel  Age  Hops  Cost  Relation                 Flags  RSSI  Rate Tx/Rx  A-Req  A-Resp  A-Fail  HT-Details     Cluster ID
    9c:1c:12:90:59:50  9c:1c:12:90:5d:91  149E     0    1     1.00  C 3d:21h:26m:15s         VLK    26    780/780     2      2       0       VHT-80MHz-3ss  3FEEF727-4ACE-4586-9817
    9c:1c:12:90:59:51  9c:1c:12:90:5d:91  149E     0    1     1.00  N 3d:21h:26m:56s         VLK    25    -           0      0       0       VHT-80MHz-3ss  3FEEF727-4ACE-4586-9817
  • 5.  RE: How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
    Posted Jun 12, 2015 06:52 PM
    Thanks for the info, Colin.
