Hello All,
If the device was initially connected to the 2.4GHz, there is no roaming trigger (e.g RSSI is good, no retries etc), but the device then "hears" 5GHz, the same SSID beacons with more less the same RSSI value - will it switch to 5GHz or not? I am not sure... There is no roaming trigger (unless the same SSID on 5GHz is another roaming criteria). l am not sure how the device will behave in this situation.
Do you guys know?
Myky
