Wired Intelligent Edge
How configration BPDU Guard on aruba 2930F SW??
  • 1.  How configration BPDU Guard on aruba 2930F SW??
    Posted May 25, 2018 01:51 AM
    Hello
    I set it on the Aruba 2930F.
    I would like to set up the BPDU Guard.
    Perhaps
    If you have a setup guide, please let me know.
    Thank you for your support.
  • 2.  RE: How configration BPDU Guard on aruba 2930F SW??
    Posted May 25, 2018 08:49 AM
    Command:
    spanning-tree <port-list> bpdu-protection
    Please check the "ArubaOS-Switch Advanced Traffic Management Guide"
  • 3.  RE: How configration BPDU Guard on aruba 2930F SW??
    Posted May 25, 2018 01:11 PM
    Greetings!
    There is also the root guard feature, which functions similar to BPDU protection, but only triggers if the port receives a superior BPDU.  To enable this feature:
    switch(config)# spanning-tree <interface> root-guard
  • 4.  RE: How configration BPDU Guard on aruba 2930F SW??
    Posted May 26, 2018 08:12 AM
    안녕하세요.
    ArubaOS가 현재 기존 Procurve의 Provision 명령어와 거의 같으므로
    아래 명령어로 적용 하시면 될것 같습니다.
    예를들어 17번 포트에 BPDU Guard를 적용할 경우
    (config)# spanning-tree bpdu-protection-timeout 300
    (config)# spanning-tree 17 bpdu-protection
    그리고 아래 BPDU 필터를 사용하면, BPDU를 필터하게 되어 연속적으로 계속 포워딩 모드로 사용할 수
    있게 하는 명령어 입니다.. Loop발생시 에는 아래 명령어를 삭제 해야됩니다.
    (config)# spanning-tree 17 bpdu-filter
    예) 삭제시
    "no spanning tree PORT_LIST bpdu-filter"
    "no spanning tree PORT_LIST pvst-filter"
  • 5.  RE: How configration BPDU Guard on aruba 2930F SW??
    Posted May 30, 2018 09:33 PM
    Hi Younglak,
    BPDU guard prevents loops by moving a nontrunking port into an errdisable state when a BPDU is received on that port.
    In Aruba OS switches this concept is implemented using the bpdu-protection command. BPDU protection disables the specific port or ports if the port(s) receives STP BPDUs.
    Command:
    ArubaOS(config)# spanning-tree <port-number(s)> bpdu-protection.
    If you just want to supress the BPDUs on that port instead of disabling the port use the BPDU filter command instead:
    ArubaOS(config)# spanning-tree <port-number(s)> bpdu-filter
    BPDU filter: Stop a specific port or ports from transmitting BPDUs,
    receiving BPDUs, and assume a continuous fowarding
    state.
