Network Management
how configure clearpass for cisco ASA device login and management
  • 1.  how configure clearpass for cisco ASA device login and management
    Posted Oct 31, 2016 02:01 PM
    is there any document or guide regarding how configure clearpass for cisco ASA device login and management. whatever using Tacacs or Radius ? I need use clearpass instead of ACS for device administration.
    but alway got error like below:
    Tacacs packet sent
    Sending TACACS Start message. Session id: 17, seq no:1
    Received TACACS packet. Session id:259580088 seq no:2
    tacp_procpkt_authen: GETPASS
    mk_pkt - type: 0x1, session_id: 17
    mkpkt_continue - response: ***
    Tacacs packet sent
    Sending TACACS Continue message. Session id: 17, seq no:3
    Received TACACS packet. Session id:259580088 seq no:4
    tacp_procpkt_authen: FAIL
    TACACS Session finished. Session id: 17, seq no: 3
    ERROR: Authentication Rejected: Unspecified
  • 2.  RE: how configure clearpass for cisco ASA device login and management
    Posted Apr 18, 2020 05:22 PM
    Hello, have you been able to complete your ASA/CPPM configuration? If so can you shed some light as I'm currently trying to use CCPM as the Radius for Cisco Anyconnect VPN user auth.
    I can't seem to get the service rule setup correctly on CPPM as I keep getting authentication failures.
    Regards
  • 3.  RE: how configure clearpass for cisco ASA device login and management
    MVP
    Posted Apr 19, 2020 03:57 AM
    @croweheadz check your other post which you have placed on the Forum. I have given some suggestions.
  • 4.  RE: how configure clearpass for cisco ASA device login and management
    MVP
    Posted Apr 19, 2020 03:55 AM
    You can use TACACS+
    Usually, i suppose, you want to have two groups of Admin/Monitoring types of enforcement.
    So i will give instructions based on that assumption that there will be:
    - User who has Read/Write capabilities (privilege level 15)
    - User who has Read only capabilities (privilege level 1)
    First, Create two roles by going to Configuration > Identity > Roles
    Role 1: TACACS_Admin_Role
    Role 2: TACACS_Monitoring_Role
    Then, go to Configuration > Identity > Role Mapping and create
    Role Mapping 1: TACACS_Admin_RoleMap
    Role Mapping 2: TACACS_Monitoring_RoleMap
    Then go to Configuration > Enforcement > Profiles
    Create two profiles with the following:
    1. TACACS_Admin_Profile and on the service select privilege level 15, on the Selected Services select Shell and on the Custom service, make sure you have:
    Type: Shell
    Value: 15
    Also, make sure you have under the commands tab, Service Type: Shell and also Unmatched Commands enabled (tick)
    2. TACACS_Monitoring_Profile
    and on the service select privilege level 1, on the Selected Services select Shell and on the Custom service, make sure you have:
    Type: Shell
    Value: 1
    After you create the Enforcement, go to Configuration > Enforcement > Policies.
    Create a Policy TACACS_Enforcement_Policy and under rules apply the rules you desire, with the enforcement profiles created.
    For the service, i would suggest the following:
    Add the devices as a Group. So first, go to Configuration > Network > Devices. Add the devices (ASA-FW) here with correct Key for TACACS+.
    Under vendor name select: CISCO (no do not select CISCO-ASA, it didnt work for me).
    Then Create a Device group under Network > Device Groups, where you place the devices you want to have access to example: TACACS_Devices
    After that, create the service for TACACS+ and on the Service Rule configure:
    Type: Connection
    Operator: Belongs_to_Group
    Value: TACACS_Devices.
    Sorry for making it so long on the post, but i hope this will help.
    If you have any issues, contact me.
  • 5.  RE: how configure clearpass for cisco ASA device login and management
    MVP
    Posted May 04, 2020 06:03 AM
    Did you solve the issue?
