How could i have change SSH port of controller from 22 to other port?
  • 1.  How could i have change SSH port of controller from 22 to other port?
    Posted Mar 06, 2018 03:07 AM
    I would like to change SSH port of controller to other port, Is it how be able?
    Thank you
  • 2.  RE: How could i have change SSH port of controller from 22 to other port?
    Posted Mar 06, 2018 03:10 AM
    You cannot, unfortunately.
  • 3.  RE: How could i have change SSH port of controller from 22 to other port?
    Posted Mar 07, 2018 01:44 AM
    well, you cannot as a supported CLI option, but, you could get creative and setup a dst-nat to handle your desired "hidden" ssh port, allow a trusted host or two, and then block all other port 22 traffic.
    # create a remapping ACL where
    # 1.2.3.4 is a trusted internal host
    # which you should have in case you make
    # any mistake in this process (else you may
    # be locked out, or, have to use webui to fix)
    ip access-list session remap-ssh
      host 1.2.3.4 any any  permit
      any   alias mswitch tcp 12345  dst-nat 22 log
      any any svc-ssh  deny log
      any any any  permit
    # now apply to the controller uplink, make sure
    # you are connected from 1.2.3.4 when you do this !!
    (620) (config) #interface gigabitethernet 1/8
    (620) (config-if)#ip access-group remap-ssh session
    (620) (config-if)#exit
    now test it from any host that is not 1.2.3.4:
    root@kali-246:~# ssh admin@1.2.3.254
    ^C
    root@kali-246:~#
    Mar 7 14:37:16 :124006:  <WARN> |authmgr|  {0} TCP srcip=1.2.3.246 srcport=50132 dstip=1.2.3.254 dstport=22, action=deny, policy=remap-ssh
    Mar 7 14:37:17 :124006:  <WARN> |authmgr|  {1} TCP srcip=1.2.3.246 srcport=50132 dstip=1.2.3.254 dstport=22, action=deny, policy=remap-ssh
    and now using the specified port, 12345
    root@kali-246:~# ssh -p 12345 admin@1.2.3.254
    admin@1.2.3.254's password:
    Last login: Wed Mar  7 14:32:20 2018 from 1.2.3.4
    (620) # profit
    (620) # show log security 5 | include remap
    Mar 7 14:37:31 :124006:  <WARN> |authmgr|  {2} TCP srcip=1.2.3.246 srcport=59634 dstip=1.2.3.254 dstport=12345, action=dst-nat 22, policy=remap-ssh
    hth.
