how could the AP 105 can locate the controller 620 through ADP ? having problem
  • 1.  how could the AP 105 can locate the controller 620 through ADP ? having problem
    Posted Aug 20, 2013 07:18 AM
    I powered up the AP 105 through AC adapter. Now I want that, AP would be able to locate the controller via Aruba Discovery protocol.
    AP 105 is powered on through AC adapter and the Green light is blinking now . whats the next step i have to do now ?
    Although the ADP is enabled on the  controller.
    Kindly help me in this regard.
  • 2.  RE: how could the AP 105 can locate the controller 620 through ADP ? having problem
    Posted Aug 20, 2013 08:00 AM
    To use ADP, the AP and the Controller must be on the same Layer 2 network.
    Also you need to make sure that the AP is able to obtain an IP address by DHCP on that network.All APs needs its own IP.
  • 3.  RE: how could the AP 105 can locate the controller 620 through ADP ? having problem
    Posted Aug 20, 2013 08:12 AM
    right now AP is not connected with any switch and not with the controller.  Have i connect it to some switch or controller ?
  • 4.  RE: how could the AP 105 can locate the controller 620 through ADP ? having problem
    Posted Aug 20, 2013 08:23 AM
    Yes! of course you have to connect it to the controller ;)
    If you connect it directly or through a switch is up to you to decide based on your needs..
  • 5.  RE: how could the AP 105 can locate the controller 620 through ADP ? having problem
    Posted Aug 20, 2013 08:39 AM
    Thanks for your kind coperation.
    Problem has been resolved.
