How create new skin and upload to clearpass?
This thread has been viewed 23 times
  • 1.  How create new skin and upload to clearpass?
    Posted Jul 13, 2016 02:26 AM
  • 2.  RE: How create new skin and upload to clearpass?
    Posted Jul 13, 2016 04:17 PM
    You cannot create your own skins. Custom skins are design by Aruba
    professional services.
    You can however use the blank skin to customize some of the HTML. There is
    also the Galleria skin which is template based.
  • 3.  RE: How create new skin and upload to clearpass?
    Posted Sep 19, 2017 11:02 AM
    This is an old thread, so maybe obsolete, but how does this relate to the editing process described in this demo video? (I can't tell what versions of Clearpass either post refers to)
    http://community.arubanetworks.com/t5/Video/Aruba-ClearPass-Workshop-Guest-5-Customize-the-Galleria-Skin/ta-p/298679
  • 4.  RE: How create new skin and upload to clearpass?
    Posted Sep 19, 2017 04:57 PM
    That video is valid, you can follow it to customize the two existing 'Galleria Skins' in the system. They work just like a template, you just change the colors, logos, etc. If you need more skins, TAC can load additional instances for you.
    You can also use the 'custom skins' and 'blank' skin to do the same thing, but those take more HTML work and aren't as easily modified.
  • 5.  RE: How create new skin and upload to clearpass?
    Posted Sep 20, 2017 01:05 AM
    Thanks, I get it now.
    Steve Bohrer
    IT Infrastructure, Emerson College
    617-824-8523
  • 6.  RE: How create new skin and upload to clearpass?
    Steve Bohrer
    617-824-8523
