How do I activate the .a channel on a 3400?
  • 1.  How do I activate the .a channel on a 3400?
    Posted Aug 21, 2014 02:38 PM
    Everything appears to be set correctly but APs do not show .a channel in monitor.
    ARM is set to multi-band / all
    3400 running 6.3.1.7
    Have compared to another 3400 that is working fine and not seeing the difference. Obviously missing something.
    Name AP Group Status AP IP Outer AP IP AP Type Switch IP .bg Clients .bg Channel .bg HT Mode .a Clients .a Channel .a HT Mode IPSEC Actions
    00:1a:1e:c9:79:02defaultup10.11.90.15N/A12510.11.1.60011HT-40mhz0 noneDisabled
    AP-PH-11D-d6defaultup10.11.91.190N/A10510.11.1.6001HT-20mhz0 noneDisabled
    #3400
  • 2.  RE: How do I activate the .a channel on a 3400?
    Posted Aug 21, 2014 02:47 PM
    How do you have your VAP configured ? To support all or just .g ?
    Also what type of APs are you using ?
  • 3.  RE: How do I activate the .a channel on a 3400?
    Posted Aug 21, 2014 02:48 PM
    Also make sure that the .a radio profile is enabled ?
  • 4.  RE: How do I activate the .a channel on a 3400?
    Posted Aug 21, 2014 03:41 PM
    Like Victor mentioned check to make sure it is enabled. Config>Ap Group>RF Management
  • 5.  RE: How do I activate the .a channel on a 3400?
    Posted Aug 21, 2014 03:58 PM
    It always the little stuff that will get you. Stupid check mark. No clue how that got turned off.
    Thank you!!!
