How do I assign a static ip address to a RAP-155p?
  • 1.  How do I assign a static ip address to a RAP-155p?
    Posted Apr 01, 2015 11:09 AM
    I am deploying RAP-155p APs in the field. As they come up, they are aquiring a dhcp address. I would like to assign a static IP to the AP after I am able to remotely contact the device. Can anyone assist? I have both WEB and cli access.
  • 2.  RE: How do I assign a static ip address to a RAP-155p?
    Posted Apr 01, 2015 11:53 AM
    It is very simple, take the Web access and follow the following steps.
    Step 1: Select the AP which you want to assign static IP
    Step 2 : Click on edit
    Step 3: Select "Specify statically" from general tab
    Hope got your answer. please feel free for any further help on this
