How do I assign VLAN to a client on IAP 205 from RADIUS server ?
  • 1.  How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 18, 2016 09:02 AM
    Hi
    I have a RADIUS server assigning VLAN to clients connecting to controller based APs, and this is working without any problems.
    Now I want to do the same thing to clients connecting to an IAP205. The AP is configured to use the same RADIUS server(freeradius) as used in the controller based setup, but clients do not get VLANs assigned.
    What is the diffrence between these 2 setups ? And why is it not working on instant ?
  • 2.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 18, 2016 09:12 AM
    What are you returning a filter-ID or an Aruba VSA "Aruba-User-VLAN" ?
    Sent from Outlook for iPhone
  • 3.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 18, 2016 09:26 AM
    Here's an example of what I'm returning.:
    Tunnel-Type = VLAN,
    Tunnel-Medium-Type = IEEE-802,
    Tunnel-Private-Group-ID = "52"
  • 4.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 18, 2016 09:38 AM
    Under the Network/SSID Client VLAN assignment do you have set to Dynamic ?
    You could also match under the VLAN rules what you are sending using the IETF attributes , Tunnel-Private-Group-ID = "52" assign VLAN = 52
  • 5.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 18, 2016 09:43 AM
    I have tried both default and dynamic.
    But if I choose dynamic, I can only add 7 rules, and I nedd to assign 30 diffrent VLANs.
  • 6.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 20, 2016 10:30 PM
    Uhmm I see , I think the other option is to return the VLAN using the Aruba VSA Aruba-User-VLAN.
    Give it a try and let us know if it works for you
  • 7.  RE: How do I assign VLAN to a client on IAP 205 from RADIUS server ?
    Posted Mar 21, 2016 05:52 AM
    It works!!
    Thank you very much for your help.
