How do I change the Virtual Controller IP?
  • 1.  How do I change the Virtual Controller IP?
    Posted Dec 01, 2016 07:37 PM
    We are in the process of moving from vlan 1 172.16.0.0/16 to vlan 119 10.3.92.0/24. I am able to get an ip from the dhcp server on vlan 119, and was even able to change the Virtual Controller IP with some success. Though my clients get an auto IP when they associate even though the dhcp server is on vlan 119. The ports that I have these APs on are all trunked with vlan 119 set to default in the new config. The old config has the ports in vlan 1 as default. Any help or direction would be appreciated.
    Here is the config from the primary AP.
    dayiap2# sh run
    version 6.4.2.0-4.1.3
    virtual-controller-country US
    virtual-controller-key
    3
    name wapvc
    virtual-controller-ip 172.16.254.9
    terminal-access
    telnet-server
    ntp-server 172.16.200.14
    clock timezone Eastern-Time -05 00
    clock summer-time EDT recurring second sunday march 02:00 first sunday november 02:00
    rf-band 5.0
    allow-new-aps
    allowed-ap 18:64:72:ca:5b:8c
    allowed-ap 94:b4:0f:c0:7b:72
    allowed-ap 94:b4:0f:c0:7e:84
    allowed-ap 94:b4:0f:c0:7f:66
    allowed-ap 94:b4:0f:c0:7e:80
    allowed-ap 94:b4:0f:c0:7f:0a
    snmp-server community 920331767de1f29a44e8a9a1f94dc67a
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 127
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user misadmin
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-instant
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule US-DAY-Wifi
    index 2
    wlan access-rule US-DAY-GST
    index 3
    wlan ssid-profile US-DAY-Wifi
    enable
    index 0
    type employee
    essid US-DAY-Wifi
    wpa-passphrase a2e28052834c759c9e8f862ddf70f7dc284a835bddaad3b6
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 119
    auth-server YAVIN
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile US-DAY-GST
    enable
    index 1
    type employee
    essid US-DAY-GST
    wpa-passphrase deleted
    opmode wpa2-psk-aes
    vlan 122
    auth-server InternalServer
    rf-band all
    dtim-period 1
    auth-survivability cache-time-out 24
    dpi
    wlan auth-server YAVIN
    ip 172.16.200.14
    port 1645
    acctport 1656
    key deleted
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    no shutdown
    access-rule-name default_wired_port_profile
    speed 1000
    duplex full
    no poe
    type employee
    no dot1x
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
  • 2.  RE: How do I change the Virtual Controller IP?
    Posted Dec 02, 2016 09:38 AM
    Hi!
    Your default port profile says VLAN 1 is untagged and rest is tagged:
    allowed-vlan all
    native-vlan 1
    So when placing clients in VLAN 119 the port will tag it and send it to the switchport. But I guess that your switchport have VLAN 119 as untagged since you say that you get an IP-address on it for the access point. Please try to change the SSID to put the clients on VLAN 1 (untagged) if you want them to get IP address from the same VLAN as the access points do.
    With that said, you might want to take a look att separating the management subnet from the acctual client subnet by placing them on another VLAN that is tagged on the switchport and doesn´t contain APs.
    Cheers,
  • 3.  RE: How do I change the Virtual Controller IP?
    Posted Dec 02, 2016 09:49 AM
    This is one switch port config that an AP is connected to before the necessary changes.
    interface GigabitEthernet1/0/1
    description WIFI AP DAYIAP3
    switchport trunk encapsulation dot1q
    switchport trunk allowed vlan 1,2,11,14,21,75,119,122
    switchport mode trunk
    spanning-tree portfast disable
    I added vlan119 as native after the changes.
    switchport trunk native vlan 119
    so I should ttry changing the ssid vlan only?
  • 4.  RE: How do I change the Virtual Controller IP?
    Posted Dec 02, 2016 09:51 AM
    Yes, since 119 is untagged on the switchside you´ll need to put the clients on the untagged VLAN of the IAP which seems to be VLAN 1.
    Cheers,
