How do I create a SAN certificate for Aruba controllers 7200s - Not using Clearpass
  • 1.  How do I create a SAN certificate for Aruba controllers 7200s - Not using Clearpass
    Posted Sep 05, 2018 06:50 PM
    I have a pair of controllers running in mode: Master-primary - Master-standby using VRRP. I need to install a SAN certificate with the controller name and the VRRP. There isn't an option on the GUI or CLI to create the DNS:alt names. Does anyone know how to create a valid CSR and cert?
     Best
  • 2.  RE: How do I create a SAN certificate for Aruba controllers 7200s - Not using Clearpass
    Posted Sep 05, 2018 07:13 PM
    Use OpenSSL to generate the CSR
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: How do I create a SAN certificate for Aruba controllers 7200s - Not using Clearpass
    Posted Sep 06, 2018 03:17 AM
    Thank you for the solution.
    Best
    Get Outlook for Android
  • 4.  RE: How do I create a SAN certificate for Aruba controllers 7200s - Not using Clearpass
    Posted Oct 10, 2018 05:18 PM
    The customer has just purchased the SAN certificates, after a long delay.
    How do I install the SSL key on the controllers? An option to load a key via the GUI no longer exist.
    KR
