Wired Intelligent Edge
How do I decrease the sensitivity of the Aruba CX 6100 to poor coms due to a poor cable?
  • 1.  How do I decrease the sensitivity of the Aruba CX 6100 to poor coms due to a poor cable?
    Posted 19 hours ago
    We replace a couple dozen HP Procurve 2530 and older switches with Aruba CX6100.   Certain devices are loosing communications ever minute or so.  The final solution is to rerun the cables.  BUT that can't be done quickly.   Far quicker would be to tweak the switches.
    The symptom is devices show ping works for a while (30 seconds to 5 min) then they get appear to have their traffic blocked for 1-60 seconds.   Then they are find for a while.   Some ports show in the log various   up and  down  for the port.   Other ports doing the same show nothing in the log and error counts are 0.
    Running a cable diagnostic shows problem pairs.  We are a production facility.  I can't get new cables run quickly enough to support the
    My current work around is have them use wireless.   If they can't do that, I hang an old HP switch off the Aruba switch to support the few devices that are on problem cabling.
    I am fairly new to the AOS-CX.  Had switch for 6 months.  Have used Cisco before the HP Procurves so have some experience in a similar OS.
    First time doing a deep dive into troubleshooting.
    I tried setting all the fault-monitor stuff to notify only.   I expect there is something similar to force the port to stay up.
  • 2.  RE: How do I decrease the sensitivity of the Aruba CX 6100 to poor coms due to a poor cable?
    Posted 14 hours ago
    You may try setting the ports to 100Mbps, if that is where they were set to on the 2530.
    Further, working with Aruba support and see if they know a solution may work.
