Comware
  • 1.  How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 08:45 AM
    Hi all.
    How do I determine how long a switchport interface has been down or up for ?  We're running ComWare switches and I have limited knowledge of them.  For example, if interface Gi2/0/2 is down, how do I determine how long it's been down for accurately ?
    In Cisco IOS you use the command show interface gigabitEthernet 2/0/2 link, so what's the equivalent in HP ComWare ?
    In case you need to know, we're running various switch models and an example ComWare version is 5.20.99, Release 6626P02.
    #link
    #Counter
    #counters
    #comware
  • 2.  RE: How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 09:02 AM
    I don't know if there is a command to show such port history.
    Link state changes are written to the switch log, so you can search for it there:
    display logbuffer reverse | inc 2/0/2
    Of course, if the port has been up for months then the log entries are probably overwritten. In that case, you could do logging to a syslog server and search there.
  • 3.  RE: How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 09:13 AM
    Thanks TerjeAFK.  I've tried that but the logbuffer only goes back a couple of days.  One thing I really need to know is which switchport interfaces have been down for a long time.  Like, say, more than 6 months.  Are there any stats I can get which would allow me to extrapolate this information ?  Surely there must be something.
  • 4.  RE: How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 02:06 PM
    Thats why you need a syslog-server which you will log to :-)
    For example:
    info-center source default channel 0 log state off trap state off
    info-center source default channel 1 log state off trap state off
    info-center source default channel 2 trap level informational debug level informational
    info-center source default channel 4 trap level informational debug level informational
    info-center loghost source LoopBack0
    info-center loghost <IP OF SYSLOGSERVER>
    info-center logbuffer size 1024
    info-center trapbuffer size 1024
    info-center synchronous
    info-center timestamp loghost iso
    undo info-center logfile enable
  • 5.  RE: How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 10:36 AM
    show interface <if> link only works on some IOS platforms (for example Cisco 4500).
    If you have a syslog server, you can enable logging on that and get the messages from there.
    Otherwise I would start looking for some way to maybe extract the info using SNMP, havent looked into what MIB that info might be. Takes a bit of researching i reckon.
    Regards
  • 6.  RE: How Do I Determine Interface Link Up or Down Time ?
    Posted Jan 27, 2015 10:40 AM
    I've discovered that our HP IMC monitoring server displays a Last Change field against each switchport interface.  This is a time stamp and seems to update when the link state changes.  I'm trying this and it looks good.
