How do I determine the wpa-passphrase for a particular SSID in InstantOS?
This thread has been viewed 23 times
  • 1.  How do I determine the wpa-passphrase for a particular SSID in InstantOS?
    Posted Jul 06, 2015 12:20 PM
    I have seen the encrypt disable command for the controller based setup. Is there a way to decrypt or find the wpa-passphrase for a particular SSID in the InstantOS?
  • 2.  RE: How do I determine the wpa-passphrase for a particular SSID in InstantOS?
    Posted Jul 06, 2015 01:53 PM
    Show run no-encrypt
