How do i do a full factory reset on a RAP 109?
  • 1.  How do i do a full factory reset on a RAP 109?
    Posted Nov 12, 2014 12:55 PM
    Hey Guys,
  • 2.  RE: How do i do a full factory reset on a RAP 109?
    Posted Nov 12, 2014 07:29 PM
    To return a RAP-109 to factory defaults:
    1. Power off AP (remove power)
    2. Press and hold the reset button using a small object (paperclip).  The reset button hole is next to the USB port.
    3. Plug the AP back in; without releasing the reset button.  The power LED will flash within 5 seconds.
    4. Release the reset button
    5. The power LED will flash again within 15 seconds indicating it is completed.
    6. The AP boots with factory default settings
