How do I do Mac authentication with ClearPass?
This thread has been viewed 121 times
  • 1.  How do I do Mac authentication with ClearPass?
    Posted Mar 16, 2013 02:08 AM
    Hello, I am working this solution now. But I have some problem with Clearpass Guest.
    I am using the Mikrotik RouterOS as a DHCP Server with Radius option enable. Client get IP Address from DHCP Server when using FreeRadius with Mac Address as username and without password.
    When I use Clearpass as radius and create a Mac Address as username, it must be include a "password" following Mac Address.
    And I try to create a device account on Clearpass Guest only Mac Address as username without password. Any idea fot this?
  • 2.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 16, 2013 08:31 AM
    You add the mac address to the endpoints repository:
    After that, you can save a copy of of the Guest MAC authentication service to Mac authenticate users (make sure you replace Guest SSID Name with the name of your SSID):macauth.PNG
  • 3.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 16, 2013 10:49 AM
    Hi cjoseph,
    Thanks for your reply.
    The Guest Mac Authentication must have "mac address as username" and "mac address as password" for authentication success.
    My problem is how authentication success only via "mac address as username" without password?
  • 4.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 16, 2013 11:48 AM
    @ansonhsu wrote:
    Hi cjoseph,
    ansonhsu,
    If you want have a list that only has mac addresses, you would create a static host list:
    To check to see if an incoming device is a member of this list:
    Let me know if that will work...
  • 5.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 17, 2013 10:51 AM
    Hi cjoseph,
    Thanks for your support.
    It's work.
    But how could I add some radius attribute like "Framed-IP-Address" and "Framed-Netmask" into Static Host Lists "Mac Address" account?
  • 6.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 17, 2013 11:24 AM
    Framed IP address is an IP address, not a Mac address, so you would have to have a list of IP addresses in your list. You probably also would need to have radius accounting enabled to get the IETF:framed IP address parameter to show up.. What are you trying to do?
  • 7.  RE: How do I do Mac authentication with ClearPass?
    Posted Mar 18, 2013 12:36 AM
    Hi cjoseph,
    Let me explain my case.
    I have a CPPM self-register portal and Clients can regist their device's MAC Address and IP Address in the register form.See Blow,
    Before client get IP Address from DHCP Server, my DHCP server will do "Mac_Auth" with my CPPM.
    after authentication successed, CPPM return Radius "Access-Accept" packet include "Framed-IP-Address" attribute to my DHCP Server.
    And then my DHCP Server will deliver a "Static IP Address" register from client  to their device.
    That's what I are trying to do.
    But I have a problem with Mac_Auth environment now.
    Because my DHCP server do Mac_Auth to Radius server with "Access-Request" packet format is below,
    The Username is "Mac Address" but the Password is ""(blank or empty).
    So I always got authentication failed(Access-Reject) from CPPM's Mac_Auth.
    Any idea for this case?
    Thanks your reply again.:smileyhappy:
  • 8.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 02:42 PM
    Is there a solution or a How to? Allow MAC authentication base only in the device MAC Address ?
  • 9.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 02:48 PM
    The guest device repository can be used for this. Add your devices under Create Device on the guest side.
    In your MAC authentication service, use [Guest Device Repository] as the authentication source.
  • 10.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:01 PM
    It is possible only to use Static Host List? I created one white list but is not letting me add mac-address without colon or Dot. I make it worked like this let me know your comments(if there is a different way). The image is the summary of the Service Service.JPG
  • 11.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:03 PM
    You can, but it's not recommended as it does not scale and provides no context.
    If you do choose to use them, remove that from the service rules and use the DHL as an authentication source.
  • 12.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:10 PM
    What will the Service look like? I dont no what DHL authentication source is, can you advise me?.
    P.S: I created a new authentication source named MAC Database to use the Static Host List "MAC-White-List".
  • 13.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:13 PM
    Create a new SHL authentication source and then add it as the authentication source for your service.
  • 14.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:21 PM
    Use the MAC Authentication service template and use your custom SHL authentication source.
  • 15.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:27 PM
    In the Authentication methods I already used Allow All MAC Auth or MAC AUTH and get the same error message
  • 16.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:30 PM
    What NAD are you using?
  • 17.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 03:47 PM
    Dell Switch N2048p
  • 18.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 04:01 PM
    Try using EAP-MD5 as the authentication method.
  • 19.  RE: How do I do Mac authentication with ClearPass?
    Posted Jan 23, 2017 04:25 PM
    If I use EAP-MD5 works fine :), any other recommendations for security purposues ?
  • 20.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 10:45 AM
    Hi Cappalli,
    When you use the Guest device repository for MAC authentication, the Authentication Method will be [EAP-MD5] and Authentication Source the [Guest Device Repository] ?
  • 21.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 11:17 AM
    Depending on the NAD, it will be Allow All MAC-Auth or EAP-MD5 for the method.
  • 22.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 11:29 AM
    Perfect thanks, will test it right away.
  • 23.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 11:41 AM
    Clearpass is rejecting the device login even dough the device was created and the status is enabled in the Guest device reposiroty, the service pulls the authorization info and assigned the corresponding role but I'm getting this error
  • 24.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 11:57 AM
    What is the authenticator/network device?
  • 25.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 05, 2017 12:34 PM
    Is a Dell N2048P
  • 26.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 06, 2017 09:20 AM
    Heads up,
    I use the Guest device repository as an Authorization Source and it started working, in the enforcement profile we compare the account_Status and Remaining_Expiration time to allow acces to the network if the account is still valid. Is possible to fetch more attributes from the tipsdb by default we only get three attibutes? like getting the MAC Address, device name, etc.?
  • 27.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 06, 2017 09:29 AM
    MAC address is available as a computed attribute. Are you looking to use device name in policy or just to see it? You want to avoid pulling data that is not being using in policy for performance reasons.
  • 28.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 06, 2017 09:31 AM
    We will like only to see it, but if impacts performance it can stay the it is right now.
  • 29.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 06, 2017 09:46 AM
    You'll see it either way under the GuestUser context within an access tracker request under Computed Attributes. Device Name is the visitor_name attribute.
  • 30.  RE: How do I do Mac authentication with ClearPass?
    Posted Apr 06, 2017 10:00 AM
    Perfect, will use that one, Thanks again for all your help with my question.
  • 31.  RE: How do I do Mac authentication with ClearPass?
    Posted Aug 03, 2018 12:26 PM
  • 32.  RE: How do I do Mac authentication with ClearPass?
    Posted Sep 17, 2018 07:40 PM
    We have similar setup for mac authentication, we use SHL. We use them for iot devices.
    How can we automate this process, by allowing users to enter the mac address via a portal and the SHL gets updated?
    Also, does aaa override work with mac auth? we want to place the devices based on the device type into different networks.
    rp
  • 33.  RE: How do I do Mac authentication with ClearPass?
    Posted Sep 17, 2018 07:43 PM
    Static Host Lists should not be used. Use Device Registration.
  • 34.  RE: How do I do Mac authentication with ClearPass?
    Posted Sep 17, 2018 08:33 PM
    Thanks Tim. Is there any whitepaper or any implementation which already exists that I can refer.
    Best Regards
    RP
