How do I enable/disable "Load Aware Scanning" in IAP
  • 1.  How do I enable/disable "Load Aware Scanning" in IAP
    Posted May 04, 2015 12:03 AM
  • 2.  RE: How do I enable/disable "Load Aware Scanning" in IAP
    Posted May 04, 2015 06:56 AM
    This feature is a native feature of ARM , which is enabled by default and we do not have any option for enabling or disabling this.
    The document is just explaining ARM and it's common features that does'nt mean that we have control over this feature.
    hope you some more clarity, please feel free if any further query on this.
  • 3.  RE: How do I enable/disable "Load Aware Scanning" in IAP
    Posted May 04, 2015 02:44 PM
    Ok, do you know what the threshold is?
    "...when the network traffic exceeds a predefined threshold"
  • 4.  RE: How do I enable/disable "Load Aware Scanning" in IAP
    Posted May 05, 2015 07:08 AM
    The default threshold is similar to controller's threshold i.e 10 Mpps.
