How do I find my appuser password to connect CPPM local SQL DB?
This thread has been viewed 24 times
  • 1.  How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 01:01 AM
    I'm testing remote connect to CPPM, I have admin account/password on CPPM, But I don't know appuser password to connect LOCAL SQL DB. (Just I can see in GUI, ●●●●●● )
    How do I find my password? Is it possible to view plain-text in CPPM CLI?
    To export known MAC-ADDRESS, I need to access CPPM tipsdb from remote LINUX box.
    Thanks.
  • 2.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 06:47 AM
    You cannot use the appuser account. Try using the appexternal account. You can set the password under server configuration > cluster wide settings
    Tim
  • 3.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 09:36 PM
    Hi cappalli, Thanks very much.
    I found password menu and success to connect my cppm from remote linux box.
    But..appexternal have not permission to read tips_endpoints database........
    I need to export mac_address from tips_endpoints database.
    Is it impossible from remote?
  • 4.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 09:38 PM
    You'll want to use the Export All option under Configuration > Identity > Endpoints in the GUI. You can then use an XML to CSV utility.
    http://xmlgrid.net/xml2text.html
    The tips_endpoints table does not contain all of the endpoint data.
  • 5.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 10:11 PM
    Hi cappalli, Thanks very much!
    But I need to export in automated shell in LINUX box, I need to studying GUI menu from shell with curl or wget. :)
    And I found 'mac' field in tips_endpoint_profiles which is read from appexternal account.
    What's this field?
    I want to sync allowed MAC address across heterogeneous infra structure. If that 'mac' field is someting allowed MAC address in my main network, It's Ok to my mission.
    Very thanks.
  • 6.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 10:16 PM
    Take a look at page 18 in the attached API guide.
    Attachment(s)
  • 7.  RE: How do I find my appuser password to connect CPPM local SQL DB?
    Posted Jan 22, 2015 11:18 PM
    Thanks very much!
    Success to export my HQ mac address!
