How do I generate a report in Airwave for Top Clients By Total Traffic?
  • 1.  How do I generate a report in Airwave for Top Clients By Total Traffic?
    Posted Jun 11, 2015 05:19 AM
    How do I generate a report in Airwave for Top Clients By Total Traffic? I'm running version 8.0.6.3.
    Thank you
  • 2.  RE: How do I generate a report in Airwave for Top Clients By Total Traffic?
    Posted Jun 11, 2015 05:23 AM
    You would create a new report definition with the type of "Client Session".   Make sure you set the "Include details about every client" parameter to Yes.  Save and Run it for the period of time you are interested in.
  • 3.  RE: How do I generate a report in Airwave for Top Clients By Total Traffic?
    Posted Jun 11, 2015 06:45 AM
    Hi Colin,
    I have created a new report definition but when I Save and Run I'm not getting the email. It's also not showing under the Generated reports.
    Kindly assist.
  • 4.  RE: How do I generate a report in Airwave for Top Clients By Total Traffic?
    Posted Jun 11, 2015 06:46 AM
    It should show up under generated.
  • 5.  RE: How do I generate a report in Airwave for Top Clients By Total Traffic?
    Posted Jun 11, 2015 06:56 AM
    Got it thanks
