how do I generate an Eval License for Controller
  • 1.  how do I generate an Eval License for Controller
    Posted Aug 23, 2016 07:00 AM
    Can't see on the Licensing portal how to generate a Eval License for a Controller
  • 2.  RE: how do I generate an Eval License for Controller
    Posted Aug 23, 2016 08:10 AM
    Click on Certificate Management.  Under that should be a menu item to Create AOS certificate.  If that does not appear, please contact support.
  • 3.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 05:57 AM
    If I try activate a new EVL-AP or EVL-PEF I got an error message how "the certificate is not compatible with this system!"
    Have anybody any information regarding this?
  • 4.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 05:58 AM
    What version of code?
    Did you activate the certificate ID to the serial number of the controller
    you're trying to install it onto?
  • 5.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 06:00 AM
    Hi capalli,
    This issue happend on the licensing portal, when I try to activate the license. My controller is 7005 and Post 5.0
  • 6.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 05:59 AM
    Did you go to Certificate Management> Activate an Eval Certificate?
  • 7.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 06:08 AM
    I use the following steps:
    Certificate Management -> Create AOS Eval License -> choose the [EVL-AP] and [EVL-PEF] I got the Cert ID.
    Activate Certificates -> Mobility Controller ->
    type the Controller serial and copy paste the cert IDs.
    When I try to activate, I got the error message what I wrote on the previous post.
  • 8.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 06:20 AM
    Do you see  "Activate an Eval Certificate" on the menu?
  • 9.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 06:21 AM
    No, only the Activate Certificate.
  • 10.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 06:40 AM
    Did you choose the right platform for the controller you want to activate for?  Choosing the correct platform when you are Creating the Eval Certificate is important:
  • 11.  RE: how do I generate an Eval License for Controller
    Posted Aug 29, 2016 07:36 AM
    Of course, but the AP license [EVL-AP] not contains any controller number. I got a feedback from the support:
    We are currently having some issues activating AOS Evaluation license through our licensing portal. This has been raised and escalated to our Aruba IT Team and we are currently waiting for an update from them. We will get back to you once our IT Team provide us update and give us the resolution about the issue.
    We do appreciate your time and understanding regarding this matter.
    So, thanks for your time and help.
