Network Management
How do I get multiple BSSID information from multiple AP's?
  • 1.  How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 06:40 PM
    Hello Team,
    Our client needs the BSSID information of all the Access Points that we got. We can actually type: show ap bss-table to the AP's and get the information, the only problem is we have more than 1,500 AP's to look into and we do not have enough time to do so.
    Is there any way we could do this before our deadline in 3days?
    Gerald
  • 2.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 06:50 PM
    Thats the correct command. It will give you the required information for all APs.
    Not sure what is the missing part here?
  • 3.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 06:56 PM
    Thanks for the reply. We have both setup.
    The problem with the controller is that we have more than 1000 AP's to list the information from, but that command shows us the information we need.
  • 4.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 06:51 PM
    What do you need to do and how do you need the information to be presented?
  • 5.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 07:15 PM
    I need it on a format that goes like this:
    AP# | SSID | AP IP Address | PHY | BSSID
    I don't really need it in that order but I need the information from
    AP1, AP2, AP3, AP4, AP5..... upto AP1500.
    I want to view them all in just a single report.
    Is there a way in Airwaves wherein I can see all these information?
    I attached the view we have on Airwaves reporting.
    Thank you so much for all your replies, I will look into all of them tomorrow. It's the end of my shift and I wouldn't like to miss the bus LOL.
  • 6.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 07:18 PM
    Thanks for all your replies!
    I am attaching a pic, I want to run this command for all the AP's of all my locations.(kinda confusing)
    We can actually do this on one location, but I want to do it on all the 1000 locations in one go.
    How can I do this in the reporting?
    Thanks!
    I'll get back to you tomorrow.
  • 7.  RE: How do I get multiple BSSID information from multiple AP's?
    Posted Feb 21, 2017 07:35 PM
    What do you need to do with the information?  Typing "show ap bss-table" will give you all of the information and it would be searchable in a text file.  You can then proceed to use any excel wizardry you want to sort and create the columns you want...
