how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
  • 1.  how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
    Posted Oct 21, 2013 04:25 AM
    in cppm ,how do i limit user for reconnect after expirey (1 hour of usage)  for 24 hours? please advise - i'am unable to understand it or make it works for months....
  • 2.  RE: how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
    Posted Oct 21, 2013 10:11 PM
    When you create the guest user you will want to make sure the account is valid for 24 hours but only active for one. Clearpass has a black list that it keeps of expired accounts where if the user tries to connect it will deny access to that account.
    Its been quite awhile since I have built one.
    You will want to use one the following settings that best fits your needs
    I believe you will need to use
    expiration_time (account lifetime)
    expire_postlogin (account active time)
     Ill ping one of the devolopers and see if they can chime in. :)
  • 3.  RE: how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
    Posted Oct 22, 2013 01:29 AM
    Thanks on the info so-far!
  • 4.  RE: how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
    Posted Oct 22, 2013 01:32 AM
    IF i need user to be able to create account for 1 hour each 24 hours.
    so its:
    expration time = 1 hour
    and the expire post_login is 24hours?
    please advise.
  • 5.  RE: how do i limit user for reconnect after expirey (1 hour of usage) for 24 hours? please advise
    Posted Oct 22, 2013 01:46 AM
    I dont have access to my lab to test localy so I couldn't tell you off the top of my head. I would need to set it up again and test it.
    I will try to get some answers in the morning from engineering. Sorry, I wont have access to test until Thurs.:(
