How do i modify an SSID?
  • 1.  How do i modify an SSID?
    Posted Dec 11, 2015 01:41 AM
    I recently set up a new IAP215 and named the Network "Test" to configure it and to learn all about it.
    I now want to change the SSID to the finished network name, however, whenever i click on Edit in Aruba Instant, it does not allow the modifcation of the SSID.
    Is this not possible, or am i looking in the wrong place?
    Thanks.
  • 2.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 04:14 AM
    That depends what version of code you are on.  In the 4.2 release, this (finally) allows you to change the essid.  You will however still be stuck with the profile name of 'Test'.
    I would suggest recreating with the name you want to make it tidy.
  • 3.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 11:57 AM
    I'm assuming the 4.2 is the instant os?
    It was installed yesterday and I installed the latest firmware for the AP.
  • 4.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 12:37 PM
    Edit the ssid and click on Advanced options, and it is in the bottom right.
  • 5.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 02:01 PM
    I don't have that option on advanced, however, I've just discovered that my AP isn't set to 'standalone' mode.
    Should I convert it as it is the only AP I have in the house?
    I'm also guessing that this may be the reason why some options are not available
  • 6.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 02:10 PM
    That didnt seem to change anything either!
    This is what i have under advanced...
  • 7.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 02:39 PM
    what is the exact version you are running?
  • 8.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 02:48 PM
    Im running...
    6.4.2.6-4.1.1.11_52666
  • 9.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 02:55 PM
    Ah ok.  That is 4.1 code, which is the second part of the version.  Try upgrading to 6.4.3.1-4.2.0.3.
  • 10.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 03:22 PM
    Thanks Michael, however, where do i find that version?
    I used the automatic way on the AP, and it says im up to date?
  • 11.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 05:38 PM
    Anyone?
  • 12.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 07:10 PM
    You should try disabling broadcast filtering on that SSID.
  • 13.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 07:15 PM
    Thanks Colin, but what would that do?
  • 14.  RE: How do i modify an SSID?
    Posted Dec 11, 2015 08:20 PM
    You only need airgrouo enabled if you are filtering broadcasts or you are not on the same vlan as your devices.
  • 15.  RE: How do i modify an SSID?
    Posted Dec 12, 2015 02:27 AM
    Brilliant!
    Thanks Colin, problem solved (albiet in the other thread! :)) )
    You sir, are a star!
    Its reassuring to know that even us mere home users still get the support.
