How do I print the VRF Heat map in a large format?
  • 1.  How do I print the VRF Heat map in a large format?
    Posted Oct 09, 2013 02:32 PM
    I appologize if this is in the wrong location. I could not find an air waves section.
    Anyway what I am interested in doing is printing out the heatmaps so that I can have a hard copy to present for the upgrade that I had to design. I need to make multiple possible layouts of each facility and It would be great if i could print out the heatmaps of the possibilities in a large scale format. I know I can export the bill of materials but it is in a .doc format and the image quality is restricted to a about the width of a standard page in portrait mode. What i am looking for is a plotter size or i would even work with a landscape legal size. I just need to know if air waves will allow me.
    Thanks for the help in advance.
  • 2.  RE: How do I print the VRF Heat map in a large format?
    Posted Oct 09, 2013 06:18 PM
    Just fired up VisualRF on my end and don't see a way.
    Looks like you'll have to just take a screenshot with a tool like Snippet or Hoversnap.
  • 3.  RE: How do I print the VRF Heat map in a large format?
    Posted Aug 09, 2016 12:05 PM
    3 years later...no solution? Bill of Materials gives this useless Heatmap image.
  • 4.  RE: How do I print the VRF Heat map in a large format?
    Posted Aug 09, 2016 01:53 PM
    If that is for planning purposes, what grid size did you configure for your building? Was the building set to scale, etc? I'm not seeing that blocky of an image in my BOM export (I asusme you are only exporting the heatmap)?
  • 5.  RE: How do I print the VRF Heat map in a large format?
    Posted Aug 10, 2016 09:21 AM
    It is a deployed network. We are getting complaint of phones dropping and not able to find APs. My manager wants to see heatmaps. I can zoom in fine on Airwave, but I need a printable file.
    The grid size is 3ft x 3ft, and I am only exporting heatmap.
  • 6.  RE: How do I print the VRF Heat map in a large format?
    Posted Aug 10, 2016 09:31 AM
    There's no high-res export. Best advice is to open in a browser on a large monitor and take a screenshot.
  • 7.  RE: How do I print the VRF Heat map in a large format?
    Posted Sep 21, 2018 01:58 PM
    2 more years...
  • 8.  RE: How do I print the VRF Heat map in a large format?
    Posted Apr 29, 2020 02:46 PM
    and another year a half...
  • 9.  RE: How do I print the VRF Heat map in a large format?
    Posted Apr 29, 2020 03:03 PM
    I don't think anyone promised that feature.
    Closing this thread because it is was opened in 2013.
