How do I remove an AP from a master controller that shows it being up when it's not
This thread has been viewed 58 times
  • 1.  How do I remove an AP from a master controller that shows it being up when it's not
    Posted Feb 12, 2015 07:51 AM
    I do a 'show ap database' and the master lists an AP as being up but the AP isn't even on the network anymore. Is there a way to force an AP off of the database. My experience has always been that if it shows the AP as being up, you can't remove it.
  • 2.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Feb 12, 2015 07:54 AM
    You can clear all stale entries by using "(Aruba3600) #clear gap-db lms lms-ip <Local IP>
    Please feel free for any furhter query on this.
  • 3.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Feb 12, 2015 08:03 AM
    Is this comnmand entered on the master with the lms ip of the local controller or is it entered on the local itself?
  • 4.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Feb 15, 2015 06:18 AM
    i would say master with the name of the AP. but as the article mentions it is a pretty safe command, so just try. be sure to report back what worked for you.
  • 5.  RE: How do I remove an AP from a master controller that shows it being up when it's not
  • 6.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Dec 01, 2016 12:40 PM
    I have a problem where an AP has been removed but still showed up on the controller but not the master. How do I remove it from the non-master? when I do the clear gap command it says it must be done on the master. Which of course doesn't see it
  • 7.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Dec 01, 2016 01:25 PM
    The AP is no longer on the network ? Can you ping it ?
    Does it shows up when you run the show ap active | include
  • 8.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Dec 01, 2016 02:47 PM
    The AP is no longer on the network ? Yes
    Can you ping it ? No
    Does it shows up when you run the show ap active | include No
    Does it shows up when you run the show ap database long Yes
    *Jon Hutchinson*
    *8B Packer Ave rm 185*
    *Lehigh University(610)758-5099*
  • 9.  RE: How do I remove an AP from a master controller that shows it being up when it's not
    Posted Dec 01, 2016 06:28 PM
    Deleting the post as I was pointing to the same command that Tim posted.
