How do I remove an AP from Aruba Central?
This thread has been viewed 57 times
  • 1.  How do I remove an AP from Aruba Central?
    Posted May 13, 2016 03:05 PM
     Someone plugged in an AP not meant for our network. How do I remove the AP from Aruba Central?
  • 2.  RE: How do I remove an AP from Aruba Central?
    Posted May 13, 2016 04:32 PM
    Should be in the device management section of Central where you can unassign a license
  • 3.  RE: How do I remove an AP from Aruba Central?
    Posted May 16, 2016 09:43 AM
    That's what I thought. However, it doesn't show up in the "Device Management" list. Do I need to manually add it, then delete it, to get it to disappear from the "Access Points" list in "Wireless Configuration?"
  • 4.  RE: How do I remove an AP from Aruba Central?
    Posted Jun 21, 2016 02:25 AM
    Is this IAP part of same vlan where other IAP's  have ?
  • 5.  RE: How do I remove an AP from Aruba Central?
    Posted Aug 31, 2016 02:16 PM
    Make sure the AP is unplugged from the network.
    Go into the monitoring section then access points subsection and find it there in the list. It should have status "down".
    Click on the name of the AP (not the little pencil off to the right), and click on the Actions menu in the upper right. Select "delete AP".
  • 6.  RE: How do I remove an AP from Aruba Central?
    Posted Aug 13, 2018 12:11 AM
    I try to follow the instructions, but its really confuse:
    1) Only i see next sections:
    MR Monitoring & Reports
    WL Wireless Management
    WD Wired Management
    MA Maintenance
    GS Global Settings
    2) I power off the AP and take more that 15 minutes in go offline
    3) I Delete AP, but when i reboot the AP, appear linked to Aruba Central but with factory values, and i can´t setup nothing, because its disabled all options.
