How do I reset AP-125 to default settings with no serial, and default login/IP?
  • 1.  How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 10:50 AM
    I am getting a "used" (supposedly open, but never used) AP-125.
    How would I go about fully resetting the unit without a serial connection, and then assuming no DHCP assigns it anything, what would be default login and IP information?
  • 2.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 10:56 AM
    You might want to power it up on the same subnet as an existing controller to see if it connects to it.
  • 3.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:23 AM
    I'm sorry, I forgot to mention that I intend to use this as a standalone unit, not as part of a controller.
  • 4.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:25 AM
    Unfortunately, the AP125 does not come as an IAP or standalone unit. It never has..
  • 5.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:27 AM
    Oh, someone told me that all the APs and IAPs had the option to go between the two configurations, was I misinformed?
  • 6.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:29 AM
    The AP125 is an older model that does not have that capability.
  • 7.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:31 AM
    What is the lowest end current model that does have that capability? (Wireless G and N, vlans, and multiple SSID are my only requirements)
  • 8.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:36 AM
  • 9.  RE: How do I reset AP-125 to default settings with no serial, and default login/IP?
    Posted May 01, 2015 11:39 AM
    Ok, thank you. I'll look into other options.
    Hopefully the AP125 is in the condition I was told and I can resell it to someone who does use a controller.
