How do I send aruba virtual controller logs to my syslog server?
  • 1.  How do I send aruba virtual controller logs to my syslog server?
    Posted Oct 04, 2013 02:57 PM
    I put the syslog server IP address into the settings on the virtual controller.
    I then created a config file in /etc/rsyslog.d called 30aruba.conf containing this:
    :rawmsg, contains, "sn=Instant-C4:57:3B" /var/log/arubawireless.log
    I set the log level to debug and restarted rsyslog, but still nothing is coming through. I also know that rsyslog is listening on UDP 514.
    Am I missing something? Any help is appreciated,
  • 2.  RE: How do I send aruba virtual controller logs to my syslog server?
    Posted Oct 07, 2013 12:08 PM
    What do your IAP ACL's look like? are you permitting the necessary UDP ports?
    If you don't have an explicit 'allow all', you can add a network specifc ACL for UDP 514 by doing the following from the PEF tab in the IAP:
  • 3.  RE: How do I send aruba virtual controller logs to my syslog server?
    Posted Oct 08, 2013 12:02 PM
    For each SSID in PEF I have allowed UDP 514 to our syslog server. See attached picture.
    I also set each facility to warning to help get more logs sent.
    I suspect it's maybe something with my /etc/rsyslog.d/30aruba.conf file which looks like this:
    :rawmsg, contains, "aruba" /var/log/arubawireless.log
    Any suggestions?
  • 4.  RE: How do I send aruba virtual controller logs to my syslog server?
    Posted Oct 08, 2013 12:03 PM
    Here is the syslog config.
  • 5.  RE: How do I send aruba virtual controller logs to my syslog server?
    Posted Oct 08, 2013 06:18 PM
    tyosick, can you confirm the IAP is sending the syslog OUT via an uplink pcap?  Optically what you have confiugred looks correct.
