How do I set TIME RANGES on a Aruba 3600 (6.1.2)
  • 1.  How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 07:36 AM
    Hi
    I have found how to create a TIME RANGE under Security > Access Control > Time Range, however I do not know how to apply this Time Range to either a specific VLAN or WLAN or User Role.  I only want to apply it to the Guest Portal and not our WLANs we use for access to our domain.
    Any advice would be apprecaited.
    Thanks...
    #3600
  • 2.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 07:43 AM
    If you want to only have a WLAN available for a particular period of Time, you would configure a "Deny" time range (when you do not want anyone to connect), then you would insert that in the Virtual AP under Deny Time Range.  Configuration> Wireless> AP Configuration.  Edit your ap-group.  Expand Wireless LAN.  Expand Virtual AP.  Click on the virtual AP you want to apply it to.  In the right pane insert your deny time range in the Deny Time Range field and click on apply in the lower right hand corner.
    Remember, the Deny Time range is the range when you want traffic to be Denied, not allowed...  Also make sure the time on the controller is set correctly, to avoid any issues.
  • 3.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 08:37 AM
    ok, great that makes sense.
    I'm in the Time Range configuration now -
    How would I set this up in Time Range?
    I want to turn off a WLAN from 7pm - 7am each weekday + all weekend?
    i just tried adding a weekend time range, but when i hit apply it just dissapears?
    thanks in advance
  • 4.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 09:30 AM
    Add a periodic range on all weekdays from 19:00 - 23:59 and 00:00 to 07:00.  Also, add a range for all weekend days.  Make sure you save that time range with a name such as "no_WLAN_access".  Then, as Cjoseph said, go into the VAP for that SSID and select the time range above from the Deny Time Range drop down box.
  • 5.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 09:45 AM
    done that thanks, but when I click apply it just dissappears, any ideas?
    Just done it  again and checked they all appeared in the 'show commands' view below
    i then click apply and it deletes all my entries.
    attached is a screenshot
  • 6.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 10:06 AM
    Are you sure you clicked the "Done" button before you click the "Apply" button?  If you click the "Apply" button before you click "Done", the changes wont be saved and the Time Range wont exist.
  • 7.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 10:10 AM
    made a slight mistake above used daily instead of weekend, started again see below
  • 8.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 10:20 AM
    No, didn't see that.  Sorry.
    Can you log into the CLI and issue the commands shown in the lower window?  That should give us an idea why these are getting rejected.
  • 9.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 10:36 AM
    haven't done this before - see below- is that correct?
  • 10.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 10:57 AM
    Once you get to the > prompt on the controller, type "enable" and enter the enable password.  Once you have the "#" prompt, type "config t", then enter the time range commands.
  • 11.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 11:18 AM
    I added each command and finished with ctrl+Z - is it automtaically written to flash?
  • 12.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 11:23 AM
    To save it, do the command "write mem" from the # prompt.
  • 13.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 11:26 AM
    should the entries appear in the gui interface?
  • 14.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 11:31 AM
    Yes.  After you entered them in the CLI (if they were accepted... do a "show run | inc time-range" to verify), they should appear in the list of time ranges in the GUI.
  • 15.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 12:56 PM
    (MC1-Sunnyvale-3600)>enable
    Password: ********
    (MC1-Sunnyvale-3600) #configure terminal
    Enter Configuration commands, one per line. End with CNTL/Z
    (MC1-Sunnyvale-3600) (config) # time-range "sample" periodic Weekday 00:30 to 07:00
    To save from CLI after completing the configuration do
    (MC1-Sunnyvale-3600) (config) # write memory
  • 16.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 02:37 PM
    All,
    Shortly, I will be moving this topic under Aruba Products > ArubaOS and Mobility Controllers.
  • 17.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 04:48 AM
    Back on it this morning -
    completed the time-range commands I need ending with (ctrl+Z) and then saved the config. (which it confirmed)
    However, there are no time-range entries when after I run show config | inc time-range.  I have also checked the GUI and none are displayed in that either.
    What the hell is going on?
  • 18.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:00 AM
    This is what I have for the defaults:
    (host) #show configuration | include range
    time-range night-hours periodic
    time-range weekend periodic
    time-range working-hours periodic
    Please tell me if you see this or not.
  • 19.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:10 AM
    nothing.
    after I run
    nothing happens
  • 20.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:14 AM
    Do you have the policy enforcement license installed?  Type "show keys" to determine that.
  • 21.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:21 AM
    No I do not have the Policy Enforcement Firewall License - please don't tell me that's the reason!
    see below
  • 22.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:31 AM
    Please open a support, case, then.  According to the command reference guide, you should be able to configure a time range without the PEF-NG license.
  • 23.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 02, 2011 05:37 AM
    ok, will do, thanks to all those that posted on this thread.
  • 24.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 03, 2012 10:55 PM
    Is there any update to this issue? I think i have the same issue.
    Thanks.
  • 25.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 04, 2012 03:33 AM
    If you need a quick answer, you might want to message the user who opened this thread, or open a case of your own.
  • 26.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 19, 2012 03:54 PM
    Did anyone find an answer to this?  I have made several support calls in regards to this and the issue was escalated to an engineer.  I even downgraded my firmware to 6.1.1.1 and 6.0.0.1.  Still no luck.
  • 27.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 19, 2012 09:19 PM
    Please let us know when there is a determination from the engineer.  Since it is escalated, he has your detailed information and he would do better than us guessing.
  • 28.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 20, 2012 04:21 AM
    I still haven't made any progress with this either.
  • 29.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 20, 2012 05:23 AM
    Pburchell,
    Do you have a case open?
  • 30.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 20, 2012 08:13 AM
    As soon as I hear back, I will update everyone.
  • 31.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 20, 2012 08:26 AM
    I don't have a support contrct with them.
  • 32.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 23, 2012 09:25 AM
    Just heard back from support.  Apparently, the PEF license is needed for this option.  Their response was:
    1)   Either the customer is running this command on a controller which do not have PEF licenses or
    2)    Customer is running this command on a local controller.
    I guess they need to update their CLI guide to reflect this info.  Hope this helps you guys.
  • 33.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Jan 23, 2012 10:31 AM
    Brilliant !!
    Thanks for the heads up.
  • 34.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 11:42 PM
    This is the correct syntax.  You need to be in "config t" mode
    -michael
  • 35.  RE: How do I set TIME RANGES on a Aruba 3600 (6.1.2)
    Posted Dec 01, 2011 09:40 AM
    I just noticed you other issue (where the time range just disappears).
    Make sure you click Add on the main Time Range screen to start configuring a new range.  Click the periodic button, then enter a name for the range.  Click the add button, fill in the range info and click done.  Once that is done, click add again and put the next range in and click done.  Once you have all of the range info entered, click apply.  The time range should be created now.  All thats left to do add it to the VAP and save the configuration.
